After removing the clutch restrictor
Old Apr 7, 2007 | 12:20 PM
03SilvaEvo's Avatar
I went to bleed the clutch. FIrst filled up the reservoir to the neck. I put in a speed bleeder in too. Then loosen speed bleeder and go in car to see the clutch pedal is all the way down! I guess it lost pressure. What to do?
Old Apr 7, 2007 | 12:23 PM
Tuner@Swift's Avatar
Pull the pedal up with your hand. You'll need to cycle the pedal a few times with your hand until you've built up enough pressure in the line to spring back up.
mikesevo8's Avatar
When you let the pressure out, the spring pressure from the clutch can't help push the pedal back, so you just have to pull the pedal back up by hand.
Old Apr 7, 2007 | 01:20 PM
03SilvaEvo's Avatar
So do this while the speed bleeder is loosened a little. Ok I got pressure to build up halfway and just kept on going till fluid was solid coming out. All is good and clutch feels so much better now!
As far as fluid levels in the reservoir go, its at the MAX line right now. Before I started all this it was between the MIN and MAX. Should I leave the fluid level at MAX or take some out?
Old Apr 7, 2007 | 01:25 PM
scottatyamaha's Avatar
1. Pedal pulled all the way up
2. Open bleeder
3. Push pedal down
4. Close beader
5. Pull pedal back up
repeat
Old Apr 7, 2007 | 03:54 PM
2. Open bleeder
3. Push pedal down
4. Close beader
repeat
With a speed bleeder,step 4 is unnecessary.
Old Apr 7, 2007 | 11:02 PM
03SilvaEvo's Avatar
Another question I had in mind. How low should I let the fluid go down until filling it back up to the neck? Should the MAX line be the lowest that the fluid should go to?
Old Apr 7, 2007 | 11:07 PM
EvoAnthony's Avatar
Dont let it go to low or it will suck in air...I would keep it no lower than half full
Old Apr 8, 2007 | 12:04 AM
ChuckP's Avatar
I toped her off after every 2 pedal cycles. Dont let it get too low our your gonna be pumping for a while.
Old Apr 9, 2007 | 05:33 PM
03SilvaEvo's Avatar
Ok the clutch is bled, pedal feels firm. Fluid level is at MAX now. Is that where it should be or between MIN and MAX?
Old Apr 9, 2007 | 05:40 PM
Silk's Avatar
Happend to me, there is a divider in the brake fluid resivoir and the brake side can look completely full while the clutch side is completely empty. You need to fill the resivor to the brim then drain a little out later if you need to
Old Apr 9, 2007 | 06:10 PM
Blue Evo 8's Avatar
Fill it up to the max line...
The clutch and brake fluid resevoir is a dual circuit system. when doing the clutch you need to make sure the fluid level does not go below the base of the filler neck otherwise you'll get air into the system which is a bad thing....
it took my brother and I a while to figure this one out....
Old Apr 9, 2007 | 10:27 PM
ChuckP's Avatar
You are gonna be fine at the max level, that is where i am.
Joshs EVO
Jul 4, 2013 08:23 AM
Mr. Move
14
Oct 16, 2011 09:27 AM
msterrorist
Aug 23, 2010 01:52 AM
cij911
Mar 30, 2009 05:14 PM
Hiboost
Aug 30, 2008 07:10 AM
