Cams
Old Apr 17, 2007 | 01:26 PM
TheMRguy's Avatar
Cams
Looking into getting Tomei Cams, Wondering if anyone had any pros or cons on em?
Old Apr 17, 2007 | 02:46 PM
fastct9a's Avatar
I have the 280s. I have them on a stock turbo setup for a while now.
Old Apr 17, 2007 | 02:51 PM
jmartinez1170's Avatar
They will work with anything make sure you get a tune after putting them in. Power gains are based on what you have done to the car already. You should see atleast 10whp more like i said based on setup.
Old Apr 17, 2007 | 03:06 PM
suekie's Avatar
Only thing i could see wrong with cams is if you do mostly highway driving; as it ups your RPMS while cruising
Old Apr 17, 2007 | 03:08 PM
theblue's Avatar
how could cams affect your gear ratio?
Old Apr 17, 2007 | 03:20 PM
jr-evilevo's Avatar
Registered User
I've had 280 Tomei cams for a long time. No complaints. I would tune asap after install but don't worry the car won't blow up if you drive it to shop. I drove from mine from Dallas Tx to Houston Tx (250miles) to get tuned.
_______________________________
act clutch
fidenza flywheel
lsd diff
invidia outlet
hks carbon ti catback
invidia test pipe
tomei cams 280
fidenza cam gears
perrin intake
forge bov
forge mbc
aluminum radiator
turbo xs fmic
walbro fp
apexi power fc
Old Apr 17, 2007 | 04:06 PM
EVO8904's Avatar
Is that with a stock turbo and how much power did you make?
act clutch
fidenza flywheel
lsd diff
invidia outlet
invidia test pipe
tomei cams 280
fidenza cam gears
perrin intake
forge bov
forge mbc
aluminum radiator
turbo xs fmic
walbro fp
apexi power fc
Old Apr 17, 2007 | 04:40 PM
iTune's Avatar
This is a totally false statement. Cams have nothing to do with gear ratios...........
Please do some research before you post.
CJ
Old Apr 17, 2007 | 04:42 PM
iTune's Avatar
I too am looking for a good set of cams....bang for buck wise. I plan on using a 20G-lt turbo in the near future, so i'm looking for a aggresive cam, but not too crazy expensive.
CJ
Old Apr 17, 2007 | 04:46 PM
gsrboi80's Avatar
CJ
Bang for you buck. BC period.
Old Apr 17, 2007 | 04:47 PM
dubbleugly01's Avatar
what!?
Old Apr 17, 2007 | 07:11 PM
iTune's Avatar
I can get HKS cams @ cost. I'm not sure about anything else, but because of this....i seriously considering some HKS 280's. I am also looking at some GSC cams, but not sure about those yet.
We shall see.
CJ
Old Apr 17, 2007 | 07:14 PM
Evol.ved's Avatar
I have BC 272/272.
My rpms at cruise went down a couple hundred RPM's. Really nice plus.
Also idle is damn near perfect.
You can get a set for 300.
Old Apr 17, 2007 | 07:35 PM
digger70chall's Avatar
how do your RPMs go down if you are doing the same speed? I'm confused....
i can see idle changing though?
Old Apr 17, 2007 | 08:59 PM
iTune's Avatar
Originally Posted by Evol.ved
I have BC 272/272.
did you dyno with those cams? I would be interested to see a chart with them. I'm thinking the bc 280/280 combo or the HKS 280/280 combo.
CJ
