Help with clutch replacement please!
Old Apr 27, 2007 | 12:45 PM
VtecGSR952000's Avatar
YES, i did search already, so if thats what you are going to post....save it!
I have an 03 evo with 18,500 miles on it. I am having some warranty work done on the car and decided to throw in a Cusco twin plate clutch. I also am going to buy a stainless clutch line, new throwout bearing, and extended slave cylinder rod.
Is there anything else I need? Mitsu is installing the clutch while the have they trans out to replace the noisy input bearing (rattle @ idle). I read one thread where one person said to replace the flywheel bolts if it is removed?? I have never done this and replaced MANY clutches! I wanna know if I need to replace these bolts and if it was also neccessary to replace the throwout bearing at 18K miles!
Also, if there is anything I missed on my list, feel free to add! Thanks!
Old Apr 27, 2007 | 01:56 PM
BlueDemon's Avatar
Yeah make sure you're there when they install the clutch just in case something goes wrong. If it does then at least you can point out what when wrong and who to blame for.
I just don't want to hear another "My clutch went to S*** after a week of install thnx to mitsu" story.
Old Apr 27, 2007 | 02:41 PM
Danny23's Avatar
Definetly replace the TO bearing as long as its apart.See if you can throw the tech a 50 dollar bill to remove the restrictor pill from the slave cylinder. And there is no need to replace the flywheel bolts unless they are damged in any way which is doubtful.
Old Apr 27, 2007 | 02:43 PM
smokedmustang's Avatar
Doesnt the stock flywheel get removed, as the twins have their own flywheels? Never looked, but I thought that is how it was.
Old Apr 27, 2007 | 02:44 PM
Curt@MrLed's Avatar
Former Vendor
50 for the pill, do it yourself for nothing... hell i even enlarged the passage on mine with a drill.. no need for new bolts, unless you got money to spend...
Old Apr 27, 2007 | 02:45 PM
Curt@MrLed's Avatar
Former Vendor
it should have its own...
Old Apr 27, 2007 | 03:21 PM
OK, I dont know why the member said anything about replacing the flywheel bolts.....I was wondering if they were stretch bolts and thought it was odd!!
I did order a new throwout bearing, extended slave cylinder rod, and stainless clutch line. Then the trans is done aside from shifter bushings....which I may go ahead and order as well!!
smokedmustang: Yes you remove the stock flywheel....can only use 1 at a time!
Old Apr 27, 2007 | 03:50 PM
And there is that .................I also had the extender rod. Stress the word had. Was told it didn't do anything. Just a heads up. Keep us posted!
Old Apr 27, 2007 | 04:42 PM
hondafan's Avatar
that's what i hear too. a waste of $.
Old Apr 27, 2007 | 07:18 PM
smoked......I was just givng you a hard time!
I am going to do some searching on the clutch rod issue. I was told you wouldnt get proper engagement/disengagement without it! I will update when I find out for sure.
WartheSecond
Lancer Tranny/Drivetrain Tech
Jun 15, 2015 05:48 AM
Kiartiger
Jun 24, 2012 02:45 PM
cnj4ever
Oct 13, 2009 06:34 PM
GLancezOZoo
Oct 1, 2009 09:44 PM
Cedricredrs
Dec 30, 2007 11:57 AM
