5th gear "grinds"
Old Apr 30, 2007 | 06:11 PM
sharkm87's Avatar
Unhappy 5th gear "grinds"
since i bought the car, (used evo 8), all gears are fine, except switchin to 5th at high rpm it will make a scrape/grind noice...
so i read other post found that you can adjuste the clutch pedal so it disengages better, and actually there was alot there to adjust, i tried it all the way at the top, and the 5th gear still grinds at high rpm ...i dont get it, should i bring it back to dealer?
Old Apr 30, 2007 | 06:14 PM
nObject's Avatar
Change your fluids if that doesnt work get a rebuild.. the more you grind it the more metal in your oil and the faster your TC goes learn from me I just spent over 4k getting both rebuilt.
Old Apr 30, 2007 | 06:18 PM
turbodude's Avatar
i'm having the same issue. I'm taking mine to the dealer this week. it seems to be a common problem. try changing the tranny an tc fluid. if you drive it hard it should be changed at least every 5000 miles.
Old Apr 30, 2007 | 06:20 PM
apagan01's Avatar
Shepperd rebuild homie, i was checking the sheperd thing and he is the evo tranny master itl go forever, you can get that ISF process it's an option you pay but it is worth it is is being used in the aviation industry even aproved by FAA if the GOV aproved it has to be top noth you know how **** is to get somthing thrue the GOV aproved specially the FAA
Old Apr 30, 2007 | 06:28 PM
evo150's Avatar
i would change the tranny fluid out. if that doesnt work then get a urethane front motor mount. the difference a urethane mm can make for shifting is night and day over a broken in mushy mm. if either of these fix your problem i would think about a rebuild
Old Apr 30, 2007 | 06:31 PM
EvoAnthony's Avatar
There is a Mitsubishi Service Bulletin about the 03's 5th gear grind....its covered under warranty. I just got mine replaced along with every other synchro in the trans under warranty here in Columbus OH by Roby Mitsubishi!
Anthony
Old Apr 30, 2007 | 06:35 PM
sharkm87's Avatar
hmm ok, not sure how to change those, but will research how to's...thx
Old Apr 30, 2007 | 06:36 PM
evo150's Avatar
Anthony
nice. if mine ever starts to grind ill have to get it looked at.
sharkm87's Avatar
Anthony
how long did this take them to service?
Old Apr 30, 2007 | 06:38 PM
JMB8606's Avatar
i have an 04 evo and my 5 gear grinds
Old Apr 30, 2007 | 06:41 PM
4G63 T's Avatar
If you need re built Do NOT send to TRE very bad experience with them.
Old Apr 30, 2007 | 06:42 PM
PcK EvO's Avatar
Anthony
Too bad for us guys with after market clutches, that tranny warranty is as good as dirt. I just recently developed a nice little grind going into 5th......sucks
Old Apr 30, 2007 | 06:43 PM
adamhw's Avatar
I know that the TC and tranny have different fluids, and compartments. So how does the metal in the tranny affect the TC. Just curious cause I've had the 5th gear grind at high rpm's for over a year now, and already replaced mt TC once, although it's "bulletproof", I don't want to test it.
Old May 1, 2007 | 03:02 PM
sharkm87's Avatar
hmm, i think i may have an aftermarket clutch, but i just bought the car a week ago, i am still under warranty....i took it to the dealer today and they said its the syncros, and for major repair they have to confirm with reg. gen mgr or something and will call me tomorrow..
Old May 1, 2007 | 03:03 PM
chrismnj's Avatar
many people has this problem
