Please Help
Old May 6, 2007 | 08:51 AM
hawaiian_evo's Avatar
i read somewhere that a bb turbo just needs to idle for little while.
so capping the breather hose wouldnt cause that cloud of smoke?
Old May 6, 2007 | 08:57 AM
Soon2BEVO's Avatar
Idle for a little while? No. It needs to be primed, period.
I dont believe the capping would cause the white smoke but who the hell knows. Its not suppose to b capped, thats for sure.
Old May 6, 2007 | 09:04 AM
ill do a run and see
but if it is the turbo how else would i be able to tell?
Old May 7, 2007 | 03:13 AM
went home did a few pulls oo and uncapped the breather hose on the crank case
1. no more smoke
2. built boost fine
3. idle a little smoother but still stumbles every now and then
ill change my spark pluggs and see if that fixes it
Old May 7, 2007 | 06:43 AM
scheides's Avatar
EvoM Moderator
Keep an eye on it, it might just smoke when oil pressure is over a certain level. It may run fine for 3 pulls and then smoke on the 4th...again talk to who you got it from & see what they have to say!
Old May 7, 2007 | 07:45 AM
will do.... thanks scheides
Old May 7, 2007 | 08:18 AM
sparky's Avatar
The way to tell if the seals are shot on the turbo is to go WOT and look in the rearview mirror. If there is a puff of smoke when you let off the throttle... it´s probably shot. Also could be the lack of ventillation. Use one of those little K&N breather filters or a hose as suggested and run it down past the block(a puke tube).
Old May 7, 2007 | 08:20 AM
im pretty sure it was a lack of venting. durring the pulls the boost build strong and there was no noise comming from the turbo.
mmmmbst
34
Apr 14, 2009 03:06 AM
zoso
Jan 21, 2009 05:22 PM
Fireball
36
Apr 26, 2007 10:47 AM
silvrevo
11
Mar 28, 2006 03:17 PM
