Brian Crower 280's Dyno #'s!
Old May 5, 2007 | 01:47 PM
EvoAnthony's Avatar
Recently I installed Brian Crower 280's with his titanium retainer and valve spring kit. All the mods on the car are in my sig. I am very happy with the power these cams put out!! Temperature in the building was 77* with 55% humidity. The first dyno graph pictured is where I had just EcuFlash, 880's, BR 3" Turboback & O2 Housing, AEM Intake, and a Ported 10.5 Hotside and I made 331awhp and 360awtq on 25psi. The second dyno graph is from today with the BC 280'added on stock cam gears. Today the #'s were 356awhp and 328awtq on 25psi!! Wow am I impressed with the new found power. I lost some low end torque but the new power up top is insane! Also to add I made 313awhp 310 awtq on pump before the cams and then it made 336awhp 327awtq on pump today. Thats a 23whp gain on pump and 25whp gain on race on stock turbo. I cant wait to get a bigger turbo now! I CHANGED NOTHING IN THE TUNE just to let you guys know, not on pump and not on race gas!!! Does anyone know what my car would make on Buschur's Dyno now???
Heres the graphs:
Graph before the cams...331awhp and 360awtq
Graph after the cams...357awhp and 328awtq
Feel free to discuss as this is one of the first true tests of the BC 280's!
Thanks,
Anthony
Old May 5, 2007 | 02:48 PM
iTune's Avatar
nice numbers! Although, it seems like you are running a bit lean...... If that was a sniffer o2s.....it will typically read about .5 leaner than actual.....but even then, that puts you in the 12.0:1 range, which is a little lean.
I am looking at the BC 280's...... i have the HKS 280's, yet to be installed.
Thanks for posting up the numbers!
CJ
EDIT: i just re-read your post.....so, you made a basline on pump, then installed the cams and made a run on 110 race gas? Thats not a very good comparison. Your post is a little confusing.....please clarify what was pump and what was 110 race gas.
Old May 5, 2007 | 02:50 PM
JordanS4's Avatar
I'd say around 315-320 whp and 300 wtq on a Mustang Dyno but that all depends
Old May 5, 2007 | 03:36 PM
EvoAnthony's Avatar
CJ
How hard is it to understand. I made 313 on pump before the cams and 336 on pump after cams. I made 331 on 110 25psi before the cams and 357 on 110 25psi after the cams.
Hope that clears things up!
Anthony
edit: The AEM wideband in the car was reading 11.0-11.3's the whole entire pulls. Oh and 12.0's on 110 isnt that lean at all just to clarify....
Old May 5, 2007 | 03:39 PM
iTune's Avatar
Anthony
your original post was a little all over the place..... What you just posted was much more direct and to-the-point.
There was really no need for the attitude......thanks for clearing that up for US.
CJ
Old May 5, 2007 | 05:12 PM
EvoAnthony's Avatar
Sorry....it took me a long time to type...my bad.
Anthony
Old May 5, 2007 | 05:15 PM
adx's Avatar
adx
32wtq lost after cams?
I agree with iTune, original post is confusing.
Old May 5, 2007 | 05:22 PM
EvoAnthony's Avatar
Yeah it kinda sux but the hp up top feels great!at least it was just a tq spike...
Old May 5, 2007 | 05:33 PM
iTune's Avatar
It's obvious by looking at the graphs that these cams shifted your power band more towards mid range and peak power.......this would be the reason for the loss of torque, which comes in at low RPMs on the stock set-up. What you also must look at, is that he gained alot of torque after peak boost until revlimiter.....so, because horepower is torque*rpm/5252..... he picked up more peak power as well.
CJ
Old May 6, 2007 | 09:28 PM
EvoAnthony's Avatar
Yes this is true iTune...good observation.
Old May 7, 2007 | 09:29 PM
EvoAnthony's Avatar
Well I wooped up on a 400hp built and vortec supercharged S2k 2 nite....god I love these cams!
Old May 8, 2007 | 07:00 AM
mudduck's Avatar
seems like a trade-off between low-end torque for topend whp to me. I guess it just comes down to personal preference.
I'm still trying to figure out how you lost so much torque with the 280's on 110 gas; but you managed to gain some torque with the 280's on the pump gas map?
Does that make any sense?
Old May 8, 2007 | 08:25 AM
EvoAnthony's Avatar
The 280's move the ENTIRE powerband to the right a lot and also to mention I lost a lot of spool time. It doesn't spool up so fast now its more gradual...thats why there basically isn't any tq spike so the tq #'s are lower but more stable across the rpm band.
Old May 8, 2007 | 08:28 AM
EvoAnthony's Avatar
Oh and the 360tq that is displayed in the first graph....the pull for that # was done in 4th gear where every other pull were done in 3rd gear..
Old May 8, 2007 | 08:34 AM
sabastian458's Avatar
I have had the 280's in my car for about a month now, and I have to say that my spool time is pretty fast.
