looking to make 400whp
Sorry I am kinda new to this stuff and i am wondering what would be the best way to make around 400whp on pump gas. The only mod i have is a txs tbe. I have a 2006 MR
stock turbo, mbc, alky injection, front mount intercooler kit , exhaust manifold-back exhaust, full pump , forge diverter valve, tune on 28 psi = 400 whp well thats what i got
and a nice clutch and flywheel to hold it!
if u want it to be done right, without money being an issue
50 trim turbo kit
aem ems
Hallman mbc
Fuel pump
Injectors
Tbe
clutch and flywheel
nice tune on the aem with race gas map
420 whp with a good 93 octane tune
500 whp or so with a nice c16 race gas tune
50 trim turbo kit
aem ems
Hallman mbc
Fuel pump
Injectors
Tbe
clutch and flywheel
its doable on the stock turbo for sure. kinda on the edge though or atleast my definition of the edge.
youl have to use alky like tarmacisblack said. if you wanted to do it without alky id go with the 20g upgrade from buschur along with ported and coated exhaust manifold and o2 housing and a ported intake manifold and 65mm throttle body, 272/272 cams, downpipe, testpipe, catback, mbc, recirc. bov, licp and a custom tune and youd be there.
20g and 50 trim are both good choices. 20g is torquier while the 50 trim pulls a little harder up top.
Only one answer to this entire thread dyno proved...
https://www.evolutionm.net/forums/sh...ight=Dynoflash
G/L!
G/L!
if you go with a larger turbo you will need larger injectors, and do it right dont upgrade the turbo untill cams and everything everyone else has said are installed
(minus alky if you choose not to go with it).
