Cams in, engine bad, please help
Old May 13, 2007 | 08:08 PM
Adam@MMS's Avatar
Thanks. Believe me, the thought of an engine teardown had crossed my mind. Car is wonderful now (and by wonderful I mean loud and fast) except now I am getting intermittent hiccups on full throttle acceleration. Had the problem once before when it was stock and the dealership fixed it claiming something was intermittently leaking boost, BOV I assume. There seems to be a lot in the threads about this problem, currently researching it. Maybe it will be resolved after the Evo Green install and a tune.
Old May 13, 2007 | 08:36 PM
ONRAILS's Avatar
is it like a fuel cut or a missfire?
your plugs might be gapped to large for the new power. try going for like .22
Old May 14, 2007 | 07:52 AM
Adam@MMS's Avatar
Gotcha. Not sure if it's a fuel cut or a misfire or something else. It feels like all the power drops away from the motor, like the time when my upper intercooler pipe blew off the throttle body. If I let off the gas and get back on it the power is back. If I leave my foot on the gas the power comes back except the car bucks from power coming off and then on so abruptly.
Old May 14, 2007 | 08:02 AM
scheides's Avatar
EvoM Moderator
You'll need to tune for those new cams. Be sure you're not running too lean; you might be hitting boost cut to.
What are your other mods?
Old May 14, 2007 | 09:31 AM
Adam@MMS's Avatar
Makes sense. I did the exhuast, intake, fuel pump and intercooler as well. FP Green and bigger injectors on the way.
Adamsturbosma
May 30, 2015 07:53 AM
GGevo921
24
Jan 4, 2012 01:47 PM
Positron
Nov 20, 2009 11:23 PM
Titaztik
Site Feedback / Suggestions
Nov 27, 2004 08:00 PM
