Cams in, engine bad, please help
Old May 13, 2007 | 05:18 AM
Adam@MMS's Avatar
Edit: Had the coils switched. Stupid mistake.
Also, this thread was made before I opened shop and was still working on my Evo as a hobby. Just saying. You can actually see the progession if you look at the list of threads I have started. -Adam
Old May 13, 2007 | 05:29 AM
CO_VR4's Avatar
Did you bleed your lifters?
Old May 13, 2007 | 05:37 AM
turbo8's Avatar
what cam gears and did you knock one of the rockers out of place
Old May 13, 2007 | 05:49 AM
Adam@MMS's Avatar
I did bleed out the lifters. Vishnu cam gears. I will check the rockers and let you know. Thank you.
Old May 13, 2007 | 06:46 AM
Adam@MMS's Avatar
My first thread and it turns out I'm an idiot. I had the ignition wires backwards. Car runs like a champ now, sounds mean. Sorry I wasted your time, I hope my next post will add more to the forum. -Adam
Old May 13, 2007 | 06:50 AM
05WhiteEVO8's Avatar
Glad to hear it was something small.
Old May 13, 2007 | 06:51 AM
hotrod2448's Avatar
Glad you got it fixed. I was thinking it had to something simple like the gap on a plug closed up or something.
Old May 13, 2007 | 07:38 AM
Randy's Avatar
How the hell you bleed the lifters?
Old May 13, 2007 | 08:21 AM
Whoop_ass's Avatar
um search
Old May 13, 2007 | 08:44 AM
Ev0cRaZy's Avatar
Evomoto.com has a good writeup
Old May 13, 2007 | 08:45 AM
Randy's Avatar
Thanks
Old May 13, 2007 | 09:01 AM
Randy's Avatar
I must be crazy or I cant see anything saying that lifters have to be bled.
Old May 13, 2007 | 07:01 PM
Adam@MMS's Avatar
The Evomoto write up doesn't include bleeding the lifters. I emailed them about it but never got a reply. There are threads on here saying that bleeding the lifters is necessary (and explaining how to do it) in order to reduce your chances of blowing out a lifter seal. It sounded logical so I did it when I swapped the cams in.
Old May 13, 2007 | 07:26 PM
s2kguy's Avatar
You only need to bleed the lifters if your also replacing the springs and retainers.
Old May 13, 2007 | 07:41 PM
ONRAILS's Avatar
the reason for bleeding the lifters is to keep from getting the tapping...
i'm glad it was something simple..
When you said you had ran the car off time i was scared you bent some valves!
