Limp Mode
Old May 14, 2007 | 08:22 AM
Noogles's Avatar
Limp Mode
Does the Evo Have a built in Limp Mode?
I still can't figure out why my car won't lean out past 10.0 AF, there are no boost leaks (holds 25psi), has new wideband and new front 02 sensor, car is tuned perfectly and form one day to the next it took a crap.
Compression is between 153-160 psi across the board.
Old May 14, 2007 | 08:33 AM
Ph3n1x's Avatar
Malfunctioning Wideband perhaps.
Put ur stock map back in and see what it reads.
Old May 14, 2007 | 08:35 AM
TeStUdO's Avatar
Are you throwing any codes? Did you put in some bad gas?
Old May 14, 2007 | 08:37 AM
iTune's Avatar
what is your octane flag at? Maybe a bad widband as well.
CJ
Old May 14, 2007 | 08:41 AM
TeStUdO's Avatar
CJ
That will definitely tell you if you are going into the low octane/timing maps.
MurderedOut09
Dec 12, 2013 05:38 PM
Thatotherguy
Aug 2, 2013 11:09 PM
Zro2Hero
Jun 8, 2013 04:31 PM
Alifx
Jan 27, 2009 09:39 AM
2StepsAhead
Sep 20, 2007 05:52 PM
