Jun Evo 8 Cam Specs???
Old May 14, 2007 | 02:38 PM
Steve@NoLimitmotors's Avatar
Anyone here have the spec sheet or the specs on JUN evo 8 cams? Thanks in advance
-Steve
Old May 14, 2007 | 03:24 PM
Ted B's Avatar
From the 'Ted B. Cam Files":
JUN 264
Advertised Duration 264 deg
Effective Duration ___ deg @ 1mm
Lift 10.5mm
Lobe Centerlines 110 deg Int / 115 deg Exh
LSA 112.5 deg
Upgraded valve springs required
JUN 272
Advertised Duration 272 deg
Effective Duration 235 deg @ 1mm
Lift 10.8mm
Lobe Centerlines: 110 deg Int / 115 deg Exh
LSA 112.5 deg
Old May 15, 2007 | 05:21 AM
ciobing's Avatar
JUN 264
Lift 10.5mm
LSA 112.5 deg
JUN 272
Lift 10.8mm
LSA 112.5 deg
Upgraded valve springs obligatory or advice?
Old May 15, 2007 | 06:17 AM
Randy's Avatar
Upgraded valve springs & retainers (since the stock ones WILL NOT fit the JUN or other springs) is mandatory, good luck trying to rev up your car with any JUN cam to 7.5k rpms or more
Old May 15, 2007 | 10:47 AM
TopLevelPerformance's Avatar
Hey Randy, why u say that? something with the juns pass 7.5?
Old May 15, 2007 | 11:25 AM
Randy's Avatar
Yes dont rev them past that point unless you have upgraded springs & retainers, those cams are way too agressive the best of them are the 272's, the 264's I honestly cant say are my favorite (and I had them installed in my car)
Old May 15, 2007 | 11:37 AM
Jean's Avatar
Jun 272's are the way to go
Steve220
Nov 4, 2012 07:56 PM
Evil Evolution
Oct 6, 2009 03:16 PM
erioshi
101
Oct 24, 2007 05:04 AM
Seba
43
Oct 17, 2006 07:44 AM
typer77
14
Oct 1, 2005 10:30 AM
