I just got a "complete" turbo kit, or did?
Old May 14, 2007 | 04:31 PM
KY's Avatar
KY
I just got a "complete" turbo kit, or did I?
I just got an RNR 50 trim. It is supposed to be complete, but is it really? Here are some pictures, can you tell me what I am missing?
The turbo housing says AR .50 and the exhaust housing says AR .63, is this correct or should these numbers match?
Should the oil feed line connect like this?
And should it connect like this to the motor instead of a banjo bolt?
Also, am I missing a bolt and the nipple for the wastegate?
This is my first turbo kit and I don't know all the answers and can't find what I need to know in search.
Thanks
Old May 14, 2007 | 04:36 PM
Noogles's Avatar
looks like all you are missing is an intake pipe and o2 housing, maybe a few bolts here and there.
Old May 14, 2007 | 04:45 PM
KY's Avatar
KY
I have an intake an o2, I didn't picture them because all that was fine. I was just wondering about the things I pictured. How much do you think to make it all good?
Old May 14, 2007 | 04:52 PM
iTune's Avatar
Thanks
The turbo looks fine, as far as compressor housing and turbine section housing is concerned. Is this a new turbo(looks new)? If it's not....you need to check the shaft for play. Also, is this a ball bearing 50 trim?
CJ
Old May 14, 2007 | 04:55 PM
Noogles's Avatar
Not BB, it's only oil cooled.
Old May 14, 2007 | 05:00 PM
KY's Avatar
KY
It is new and shaft play is less than my stock turbo (30k miles) which isn't much. From the looks of things and further research I need to complete my tial wastegate and get a couple bolts. Right?
Old May 14, 2007 | 05:04 PM
kimletrim's Avatar
Registered User
You have your oil fittings reversed.
Old May 14, 2007 | 05:10 PM
KY's Avatar
KY
Are you sure? The one on top of the turbo goes by the oil filer for a feed line and the one on the bottom goes where the stock return is, right?
Old May 14, 2007 | 05:15 PM
Late Apex's Avatar
that turbo looks like those ebay xs power ones.... take better pics of the turbo.
Old May 14, 2007 | 05:16 PM
kimletrim's Avatar
Registered User
^^The stock oil line fitting uses a flange so the aftermarket line should also use a flage at the oil pan.
Old May 14, 2007 | 05:33 PM
KY's Avatar
KY
I am going to see if I can find a new fitting for the oil return. I am supposed to cut the stock metal hose and slide this one over it.
Here are some more pics of the turbo
Old May 14, 2007 | 05:48 PM
Jakeg97's Avatar
sorry to see
rnr is out of business cause of crap like that
https://www.evolutionm.net/forums/sh...d.php?t=261671
https://www.evolutionm.net/forums/sh...d.php?t=244225
Old May 14, 2007 | 06:39 PM
iTune's Avatar
duh....haha good eye!
CJ
Old May 14, 2007 | 07:45 PM
BBS's Avatar
BBS
Why do people still purchase from RNR?
cssaddictm4's Avatar
You dont need any connection on the top of the wastegate if you are using a manual boost controller.
