400 whp possible?
Old May 15, 2007 | 12:28 PM
Curt941's Avatar
400 whp possible?
On a stock turbo, with the mods in my Signature plus the following:
Snow meth kit
Cams (GSC S1?)
Walboro pump
bigger injectors
Forge Recirc BOV
running 27-29 psi?
Old May 15, 2007 | 01:30 PM
Curt941's Avatar
anyone?
Old May 15, 2007 | 01:34 PM
pjsevo8's Avatar
What kind of fuel and what king of a dyno?
Old May 15, 2007 | 01:45 PM
krazy srt4's Avatar
if ur stock turbo u should go with gsc stage 1 cams
Old May 15, 2007 | 01:47 PM
Ted B's Avatar
27-29 psi won't matter much where '400whp' is concerned because the turbo won't be holding anywhere near that at the power peak.
Your goal is possible, but you didn't disclose the size of the meth nozzle, and of course, much of it depends on the tune. Also, some adjustment to the cam settings could help somewhat, but we're probably talking nickels and dimes with the stock turbo.
Old May 15, 2007 | 01:49 PM
mudduck's Avatar
yes, has been done quite a few times on a Dynojet. Theres a member on here (forget name) putting down 405whp/415wtq on a IX with stock turbo and meth.
BTW, make that S1 cams - S2's are for GT35r and larger turbos...
Old May 15, 2007 | 01:52 PM
Curt941's Avatar
Ok, so S1 cams, check, didn't know that about them.
As far as nozzle goes, no idea.
I'd be running 93 octane.
Old May 15, 2007 | 01:54 PM
Tarmacisback69's Avatar
possibly
Old May 15, 2007 | 01:56 PM
evolsk8r's Avatar
You should be there with those mods. I put down 401whp and 417tq with the mods in my sig. on 100 octane. You don't need to get bigger injectors though. Doesn't make sense unless you're going with a bigger turbo.
Old May 15, 2007 | 02:03 PM
TeamTurtle's Avatar
I'm not too sure on 93 octane.
Old May 15, 2007 | 02:06 PM
evolsk8r's Avatar
He said methanol too.
