Green Numbers from today.....Thanks CFT!!
Old May 15, 2007 | 05:30 PM
mudduck's Avatar
oh, well that's a relief then...
So, (quickly does math on 3x5 card... ) on 18psi you put down:
~ 400whp/360wtq - sounds kind of high to me for that boost on pump gas, but if so, that would be amazing!
Old May 15, 2007 | 05:34 PM
PcK EvO's Avatar
hopefully something around that lol
Old May 15, 2007 | 05:39 PM
mudduck's Avatar
but I thought you were going to run meth???
Old May 15, 2007 | 05:42 PM
PcK EvO's Avatar
i gotta install that then ima go run it again.... cant wait for thouse numbers
Old May 15, 2007 | 07:04 PM
Blkstreak's Avatar
On 18psi?
Congrats man
Old May 15, 2007 | 07:14 PM
dmit's Avatar
dyno jet is 10 percent more right, and you could run alot more boost especially if you run meth or alky
Old May 15, 2007 | 07:17 PM
Jeff_Jeske's Avatar
I wouldnt even worry about what the numbers would be. Enjoy the tune you have and get that meth installed. I just added alchy injection and holy crap does it make a difference. I got about 4* more timing and 4#s more boost with zero knock. I'm sure the Green would simply love breathing the ****.
Old May 15, 2007 | 07:41 PM
PcK EvO's Avatar
oh yes meth is goin on this week, snow performance here i come!
Old May 15, 2007 | 08:33 PM
Viciouslord's Avatar
get logged... and make sure everything looks good... i dont trust CFT...
Ludikraut's Avatar
Originally Posted by PcK EvO
they said they didnt wanna cuase heat soak cause it was hot as hell today and the engine temps were real high
but even at a 18psi tune couldnt i crank it up?
If they knew what they were doing, then the timing on the car should reflect the fact that you're only running 18psi. DO NOT just turn up the boost. If you want to run more boost - which theoretically you can - then get it retuned. Otherwise, just wait for your alky tune. I'm sure you'll be happy.
l8r)
Old May 15, 2007 | 08:40 PM
joeymia's Avatar
unless that dyno has changed since the last time i was there it reads like a dynojet.
Old May 16, 2007 | 02:25 AM
ONRAILS's Avatar
Just wait till you get your meth tune. to turn it up it'll give you something to look forward too
Old May 16, 2007 | 03:02 AM
vboy425's Avatar
Originally Posted by atlvalet
340 on a mustang should be 400ish on a DynoJet IIRC.
you're on crack. 340 on mustang is about 370-380 on dynojet.
Old May 16, 2007 | 03:21 AM
05WhiteEVO8's Avatar
Their dyno reads very high, I have seen someone on a 50 trim put down 565 and over 500ft/lbs at 30PSI.
Old May 16, 2007 | 04:39 AM
TeStUdO's Avatar
It has to read high. Your numbers look ok for 18lbs of boost. I would get tuned someplace else after the meth gets put in. There are alot of shops in Florida that specialize in Evos. CFT is more of a Honda shop.
