FP Green - Which Cam Combo is best suited for this turbo.
I've seen this question posted before but nobody answered it except buschur stating that the Jun cams where no good for this Turbo.
What I want to know is.. What HKS cam combo would be best for this turbo.
A friend of mine has 264 I, 272 E HKS Cams
while another has 272 I, 272 E HKS Cams.
Does it make a difference to go straight 2 X 272's or downgrade to straight 2 X 264's. Or is another CAM manufacturer better overall.
Can someone Chime in with any info. And Yes I searched.. This question was posted before but never answered. If someone has actual Dyno Numbers or personal experience.. or explanation of reasons that would be great.
I already had HKS 280i/272e when I swapped out my old TME for the Green. If I were going to buy a set of HKS cams especially for the Green, I'd probably try 272i/264e and a set of adjustable sprockets. It still spools pretty decent with the present cams set at +1/-1(20# @ 3700 RPM).
I have regular old GSC 272's. I hit peak torque at 4200.
Always puts a
on my face.
Revolvers are hit and miss. 280's move the powerband too much to the right for my taste. Buschur does not recommend his special grind cams for a turbo as small as the Green.
Always puts a
on my face.Revolvers are hit and miss. 280's move the powerband too much to the right for my taste. Buschur does not recommend his special grind cams for a turbo as small as the Green.
