How long did you ACT last?
Old May 17, 2007 | 06:09 AM
goosey2099's Avatar
I had act 2100 w/ xact flywheel and the disk lasted only 20k. Thats without a turbo but with 1 year of reallll abuse. Time to get a 2600
Old May 17, 2007 | 06:22 AM
meckert's Avatar
You need to consider a few things...did you have the fly wheel resurfaced when you replaced the clutch...hopefully yes, if not..possible issue with slippage..If you are loosing clutch fluid---you have issues.. Check adjustment again-not by how the clutch feels with your foot...but follow the directions...you could easily not be releasing the clutch pate all the way do to adj and have caused the clutch to glaze and slip..Do you ride the clutch--slip it costantly at lights etc...just a few ideas...not attempting to flame in any way...just help..
Old May 17, 2007 | 09:19 AM
E VOL IX's Avatar
No i put in the streetlite flywheel when I replaced it. Since I put it in I have always had the clutch adjusted pretty high almost all the way out. I have only adjusted it twice since then. I might adjust it all the way out to see how it feels. Maybe I have it too far in and it is not fully disengaging.
Old May 17, 2007 | 09:24 AM
dsmfan95's Avatar
I have 6500 miles on my HDSS Lots of drag strip passes.
Old May 17, 2007 | 09:38 AM
lbcevo's Avatar
I have 13,000 miles on mine with a 35R and 401 WHP on 91. I don't launch, but I do redline my car often and run 25 psi half the time. Mine has broken is very well and makes almost no noise now--much less than my stocker did.
Jhurley_EvoVIII
14
Dec 8, 2015 12:47 PM
Olms2468
Oct 7, 2013 10:34 AM
08mitsubishigsr
33
Feb 12, 2013 12:21 PM
Mforbes
Dec 17, 2012 07:33 PM
Don Q
23
Jan 10, 2011 03:37 AM
