2.1 stroker
2.1 stroker
does anyone have slowboy's kit and if so any reviews ?
http://www.slowboyracing.com/estore/...2&cat=2&page=1
& Yes I did search but i'm in search of additional information if anyone has any, factual and oppinions are both welcome.
slowboy carries a 2.1 destroked kit for $1600.
AMS sells the whole race 2.1 destroked block etc for $9000...now that would be the best route to go if money was no issue.same motor they have in the shop car i believe.
you can also go with the 23RR which is a 2.3L but revs like a 2.0L or $7500 from AMS...you get the high revs and torque.ive heard great things on that motor.
Now personally building a 2.0L would be a great route and cheapest.you can use stock crank.just pistons,rods,bearings,etc..and your pretty much done..
i am doing research on the 2.1L as well..Curt Brown was running the SBR 2.1L destroked when he made his record stock turbo pass i believe(10.4) as well..He eventually threw a bearing.
a 2.1 will allow a little more torque but the main attraction is that they can be spun upwards of 11-12k .
IMO it's a drag racing application. If i were you DUBY, i'd go with a 2.3
If you want i'll take you for a ride in mine and you can tell me what you think.
-Rez
-Rez
If you do get a 2.1L dont buy it built from slowboy dont even buy parts from them either. They are the worse vendor on here. They F***ed me over on my kit it took 4 months to get and they send the worng parts 3 times in a row and asked my shop to get the right parts then they would refund them. They have no clue what they are doing. Just slap some parts in a box and hope they work.
out of curiosity, how does adding only 0.1L of displacement for the $$$$ suddenly make such a big difference in torque and spool?
(disclaimer - I do not own a stroker - yet) - but I would think if you were going in this direction, you'd go for a 2.3L...
it's not about the torque and spool, it's about the fact that it's a shorter stroked 2.1 that can rev way higher than a standard 4G63 2.0.
so, in essence, it's taking a 2.4 4g64 and destroking it to allow for better high end rpm's?
but, it's still a 2.1, so why would it be able to rev higher than a built 2.0?
because even though the displacement is there, the engine uses a shorter stroke which enables it to rev higher. kinda like a ferrari v10 that revs to 8 or 9k. lots of cylenders, lots of displacement, short stroke, and lots of RPMs.
