Strange Gear Problem
Old May 29, 2007 | 01:10 PM
FiftyFive's Avatar
Originally Posted by DaWorstPlaya
When the car is moving it going to be harder to get into 1st but if this is happening when the car is not moving then you have a different issue. Sounds like there is something wrong with your shift fork/linkage (possibly bent). Same thing happen to a friend of mine would go into 1st sometimes with no problems and would lock out other times. It turns out his shift fork was broken! Check that ...
Good point, how exactly would i check that?
Old May 29, 2007 | 02:42 PM
Ookami's Avatar
It was part of the shift linkage that was damaged. To be more specific, it was one of the posts the shift linkage bushings go into, I believe it was the one on top. It also didn't help that one of my bushings was being held on by a nail!
If you've changed out your underhood bushings I'd highly consider looking into this area as the culprit.
Old Nov 5, 2007 | 05:36 AM
FiftyFive's Avatar
In case anyone was wondering what happened. Schaller Mitsubishi put the shift linkage in backwards when working on the transmission. I brough it to another dealer, they have corrected it.
Old Feb 24, 2008 | 02:36 PM
FiftyFive's Avatar
Same issue is happening again, but now it won't go into first at all!
Old Feb 25, 2008 | 05:27 AM
FiftyFive's Avatar
Any other ideas? I am debating whether or not i should take it to the stealership this weekend.
Old Feb 25, 2008 | 05:43 AM
dueces's Avatar
I would have to agree with TTP, on it being your synchro spring. My second gear is doing this exact thing right now, I can get it to go into 2nd about 1 out of 100 trys. But if you do find something different please post it so that it could help the next person.
John
Old Feb 25, 2008 | 06:52 AM
FiftyFive's Avatar
I guess ill take it to the dealership and let them check it out again. This is the 3rd time the car is going in for this stupid transmission. It was already rebuilt.
Old Feb 25, 2008 | 07:00 AM
dino21's Avatar
if it happen just in the mornings when the car and the fluid are cold its normal,but when it happen during the day,or as you are driving and stop the car and you have still this problem,,i really dont know what could it be. im sorry
Old Feb 25, 2008 | 07:06 AM
FiftyFive's Avatar
Yea it happens all the time.
Old Feb 25, 2008 | 07:10 AM
dino21's Avatar
try to change to gear fluid,and see if its continues...
Old Feb 26, 2008 | 05:15 AM
FiftyFive's Avatar
So i have an appointment on Monday. I do have lowering springs on the car, that shouldn't be a problem w/ the warranty, should it?
Old Feb 26, 2008 | 08:20 AM
FiftyFive's Avatar
Anyone?
Old Feb 28, 2008 | 07:28 AM
FiftyFive's Avatar
Anyone?
Old Feb 28, 2008 | 10:40 AM
mithrandir7533's Avatar
Bleed the system
Bleed the clutch line. Do a search on me and see my other post. Clutch is not fully disengaging.
Old Feb 28, 2008 | 07:55 PM
skibo84's Avatar
I've had this problem with almost every car I've owned. It happens. I dont think ne thing is wrong. I know that some cars have a type of safety thing, where you have to go into first gear before you can get in reverse. I think its just point your at in the tranny that just need to go somewhere else first to align right. maybe i'm wrong though, I just know that is how some other vehicles are.
