Single or duel vavle springs
Old May 26, 2007 | 11:55 AM
Whoop_ass's Avatar
Originally Posted by nos51
i just installed the ferrera duel valve springs.i ordered them with the new spring seats which you need,retainers and thier valve lockers.bolts right in with no mods.i also installed the gsc s2 cams along with it
NOS51 what turbo you running dude...35r or a 37r?
you say the ferrera springs where a drop in.
does it not come with the valve seats or must you order those extra
please let me know as i sold my single Supertech to a mate of mine and need to replace with new one and may as well go with the duals.
i also have S2 cams with a AMS GT35r
gonna run it with stock block and stock head for now.
Old May 26, 2007 | 04:00 PM
nos51's Avatar
i am running a gt4067r.you have to order everything,vale springs,the seat for the duel valve springs,and you have to use the ferrera valve lockers.everything drops rights in.you just remove your old springs seat with a magnect and throw in the new seat.really straight forward.btw my turbo seems to spool a bit quickers with the gsc cams.i am dynoing with mase on monday i will let you know the results.my car was making 611 hp with hks 280s @32psi.
Old May 26, 2007 | 09:48 PM
TTP Engineering's Avatar
Dual springs are strong and progressive from Supertech. We run supertech dual springs. Special smaller valvestem seals are required. Ti retainers and seats are available also. We run bronze supertech intake guides and Ferrea copper exhaust guides with black nitrided intake and exhaust valves.
Inconel valves are available in oversize only.
Old May 27, 2007 | 08:20 AM
03evoyellow's Avatar
How high could you rev to with upgraded springs and retainers on stock head and block. Well i have comp 272 cams. I have a sc61 and im running out of RPMS.
Old May 27, 2007 | 09:40 AM
Whoop_ass's Avatar
ye man pls keep us posted buddy
so you reckon if i buy the ferrea i need the springs, retainer, and the valve lockers.
no valve guide work or smaller seals required.
is this correct. I don't want to pull of the head or stuff around with changing guides
and or seals.
thanks for all the info NOS51
btw are the ferrea retainers titanium?
Old May 27, 2007 | 06:02 PM
nos51's Avatar
and or seals.
well it is pretty much a kit,so yea you all of it to make it work but you do not need to pull your head.just swap them in and done.depending on the mielage of your motor you could replace your valve seals since you are there already there but the ferrera set up does not require for you to change out your valve seals to a different style.hope this helps.and the retainers are titanium.this is a very good kit even though it is pricey,but it straight forward.other kits maybe cheaper but they require .you do change a whole bunch of stuff to make it work
Old May 28, 2007 | 04:08 AM
Whoop_ass's Avatar
Sweet man thanks for all the info
now to just try find a vendor who has this kit
thanks for all info there nos51
Old May 28, 2007 | 04:13 AM
Whoop_ass's Avatar
ohhh BTW do you think there should be a prob running the Ferrea Valve springs and retainers on the EVO IX
i dont think there is a difference between the 8 and 9 valvetrain but you never know
your input greatly appreciated
thanks
Old May 28, 2007 | 07:03 AM
nos51's Avatar
thanks
i am pretty sure its the same stuff.
Old May 28, 2007 | 09:05 AM
Whoop_ass's Avatar
Old Sep 8, 2007 | 02:42 AM
RickU's Avatar
+1
Old Sep 8, 2007 | 07:28 AM
psphinx81's Avatar
supertech singles, u can rev to 8500 easily, duals.. 10k easy
singles will work perfect unless youre revving to 9k lol
Old Sep 8, 2007 | 07:35 AM
About 7850-8000.
You risk stretching rod bolts after that.
Old Sep 8, 2007 | 08:16 AM
Whoop_ass's Avatar
if you had to replace rod bolts would it be fine to rev it to 8.5k
Old Sep 8, 2007 | 02:07 PM
CO_VR4's Avatar
The two weak links when it comes to higher than stock RPMs are the valve springs and rod bolts. The stock springs cannot maintain contact with the cam lobes on high ramp angle or lift cams, and if you want to rev higher, then you'll need to decide how much higher and whether you need to go single or double based on the cams you select and the upper RPM range you want to use.
Rod bolts fatigue, and since piston/rod accelleration loads increase dramatically with additional RPM, it is common for people who have rev'd their motors on stock rod bolts to have a failure either then or later, as the stretch in the rod bolts causes increased clearance in the bearings and then creates bearing damage.
If you want to run your 4g63 hard, replacement of these two parts with higher strength parts are in the definition of basic maintenance.
