Help me diagnose..
Old May 27, 2007 | 08:39 PM
ChuckP's Avatar
Help me diagnose..
I just finished installing an 02 housing an 3" downpipe. My other mods consist of 3"TBE, aem intake and an ebc.
Now when my boost reaches about 12-14 psi, my car shutters violently and looses all power. This happens whenever the throttle is more than half way down. Is this what fuel cut is?
Car has never been tuned, but is going in on wed. for that. BTW IX, stock turbo, pump gas.
Old May 27, 2007 | 08:50 PM
AJsGenerX's Avatar
I say it's a misfire. Replace all the plugs.
Old May 27, 2007 | 08:54 PM
ChuckP's Avatar
This only started after i installed the 02 and DP, do you realy think it could be the stock plugs with 11k on them?
Old May 27, 2007 | 09:19 PM
sparky's Avatar
Which AEM intake is it? Which EBC did you get? Where are you taking it for a tune?
Old May 27, 2007 | 09:27 PM
ChuckP's Avatar
AEM short ram, blitz sbc id 3, GST motorsports.
Old May 27, 2007 | 10:17 PM
EVO+IX+MR+SE's Avatar
u need a tune
Old May 27, 2007 | 10:46 PM
sparky's Avatar
Originally Posted by ChuckP
I just finished installing an 02 housing an 3" downpipe. My other mods consist of 3"TBE, aem intake and an ebc.Now when my boost reaches about 12-14 psi, my car shutters violently and looses all power. This happens whenever the throttle is more than half way down.
Before you installed the O2 hsg., and DP, the car had been running just fine with the intake, EBC and exhaust? I'm just trying to isolate at which point of your mod sequence, the problem 1st presented itself.
Old May 28, 2007 | 12:15 AM
ChuckP's Avatar
Yes, the car had a catback w/ test pipe, aem intake, blitz ID3 and LICP, it idled and ran awsome, never had a single hiccup.
Immediatly after i installed the 02 housing and DP, the car hessitates around 14psi and has a pulsating feeling, almost like a bouncing off the rev limiter kinda feeling.
Im pretty sure the tune will take care of the problem. Just wanted to see if anyone had experienced this before, and knew exactly why it happens.
Old May 28, 2007 | 12:35 AM
JohnEB's Avatar
When you installed the 02 housing did you take the turbo off or just take the radiator out?
Old May 28, 2007 | 01:27 AM
ChuckP's Avatar
Took radiator out. Never touched turbo or manifold.
Old May 28, 2007 | 01:47 AM
JohnEB's Avatar
Did your peak boost warning get reset (on your ebc) somehow during the install?
Old May 28, 2007 | 02:17 AM
ChuckP's Avatar
No, the blitz ebc setting remained the same.
gigitalon
Jan 18, 2017 04:24 PM
rawspecs7
Aug 12, 2016 06:34 PM
ddcha
11
Jan 3, 2007 02:04 PM
chrisalishuss
Jun 18, 2006 02:31 AM
Scot
Mid-Atlantic Region
16
Nov 16, 2005 02:57 PM
