Probably a long shot, but does any have the detail below for the standard JDM 8MR Cams?
Inlet opening angle:
Inlet closing angle:
Exhaust opening angle:
Exhaust closing angle:
Overlap: (obviouisly I can work this out if I have the above info.)
I have the following details so far, but can't find the above:
Inlet Duration: 260 Lift: 10mm Peak Lift Angle: 113*
Exhaust Duration: 256 Lift: 9.5mm Peak Lift Angle: 110* (or 112*) depending which source you beleive.
Cheers
Keith
Cheers
Keith
Assuming this info is correct ...
JDM EVO MR
Advertised Duration 260 deg Int / 256 deg Exh
Effective Dur ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift 10.0mm Int / 9.5mm Exh
Lobe Centerlines 113 deg Int /112 deg Exh
LSA 112.5 deg
... the calculations are easy. If we know the advertised duration numbers and the lobe centerlines, we have everything we need.
Intake:
260/2 = 130
110 deg ATDC - 130 deg = Intake Open @ 20deg BTDC
110 deg ATDC + 130 deg = Intake Closed @ 60 deg ABDC
Exhaust:
256/2 = 128
112 deg BTDC - 128 = Exhaust Open @ 60 deg BBDC
112 deg BTDC + 128 = Exhaust Closed at 16 deg ATDC
JDM EVO MR
LSA 112.5 deg
Intake:
260/2 = 130
Exhaust:
256/2 = 128
Thanks for that,
I did think of working it out that way but wasn't sure if it would work as i don't know if peak lift was the same as the center line of the lobe. Thinking about it now it's fairly obvious.
Regards
Keith
Regards
Keith
