5th Gear Grinding
Old May 30, 2007 | 08:34 PM
beemerfreak's Avatar
Originally Posted by groove304
I had luck with my warranty claim. BUT...I have heard horror stories. Your exhaust cannot cause synchro and tranny problems. Probably don't have to take the exhaust off but it wouldn't hurt. The less they can point the finger at you abusing the car, the better. Mitsubishi knows about this grinding problem in thier trannys. It's BS that half the IX's on here have some sort of tranny/sychro/grinding issue (imo).
Can they decline my warranty for having a TBE?
Old May 30, 2007 | 08:56 PM
bump
Old May 30, 2007 | 10:19 PM
evoIX15's Avatar
my 5th gear has grinded ever since i drove off the lot...i just deal with it until the time comes to fix it...
Old May 31, 2007 | 05:23 AM
groove304's Avatar
God I hope not. But I cant answer that. They can do pretty much whatever they want if they say you were abusing the car. There are so many people that have had their car from day 1 and have the same problems. People assume abuse but I think we just got the bad trannys.
Old May 31, 2007 | 07:23 AM
Bonestock!'s Avatar
Dont give them any ammo to shoot you down with. 100% stock... but then they willl still use the old "you abused it" excuse. GL either way.
Old Jun 7, 2007 | 09:55 AM
I dropped off my car at a Mitsu dealer on Tuesday and I just called them. They said there changing my syncros under warranty.
Thank God
BTW I put my car back to stock. So I didn't have to hear ****.
Old Jun 7, 2007 | 04:00 PM
groove304's Avatar
Nice. Congrats, you beat the system. Take it easy on your shifts for a while. I would break it in like its a new car again.
Old Jun 7, 2007 | 04:58 PM
Thanks i feel a lot better now. Yea ur right for sure im going to take it easy for now on.
Old Jun 21, 2007 | 11:03 AM
WTF 2 weeks later and its starting to grind again.
My 5th gear and my 3rd slightly.
What do u guys think could be the problem?
Old Jun 21, 2007 | 11:29 AM
Chemwarrior's Avatar
I just started getting this grind. I have only smelled burnt clutch twice while I've had this car. I'm looking at replacing the transmission fluid with some BGII, but I can't find any locally. I want to see if that will help before I have to put everything back to stock in order to have the dealership look at it. I only get this grind if I'm shifting quickly and at some what a high rpm into fifth gear. The car is only two years old and has about 13000 miles on it. I've read the transmissions were weak in our cars, but I didn't figure they would be that fragile.
Old Jun 21, 2007 | 11:43 AM
I had the same problem 3 weeks ago. Then Mitsu changed my 5th gear syncro 2 weeks ago. But now the problem is back. With a added 3rd gear grind.
Old Jun 21, 2007 | 12:42 PM
dudical26's Avatar
sounds like maybe your clutch is not disengaging all the way. You could try and bring it back again and tell them you are having the same problem but also in thrid. They might say you dont know how to drive. Ask them if they adjusted the clutch last time.
Do you always push the clutch down completly when shifting?
Old Jun 21, 2007 | 01:27 PM
Yes I always push the clutch down completely.
This is starting to become a hassle, its keeping me from modidng my car.
Old Jun 22, 2007 | 02:23 PM
flybyevo's Avatar
I have the 5th gear grinding on my '03. Mostly at redline shifts. I just confirmed with Mitsubishi that I have a 5 year 60k warranty. Does anyone have any dealer they can recommend to do this repair?
Thanks
Flybyevo
Old Jun 22, 2007 | 03:34 PM
thatguy's Avatar
If funds permitting I would just send it to shep and then continue to mod you car.
Good luck, on which ever way you go.
