20G-LT / FPGreen boost and IDC data
Old May 31, 2007 | 12:57 PM
RazorLab's Avatar
Was doing some logs last night and got some interesting data:
3rd gear @ 7031 rpm = 94.5% IDC (24.57psi)
3rd gear @ 7562 rpm = 95.18% IDC (23.22psi)
4th gear @ 7094 rpm = 93.83% IDC (23.61psi)
4th gear @ 7500 rpm = 94.28% IDC (23.99psi)
11.5-11.6 afr - 100 octane
Denso 720cc injectors
Mods in sig.
Old May 31, 2007 | 06:48 PM
Aby@MIL.SPEC's Avatar
nice informative post w/data
what w/g actuator are you running?
Old May 31, 2007 | 08:12 PM
mudduck's Avatar
so what exactly does this mean?
that 720's might be cutting it a little close with a maxxed out Green?
Old May 31, 2007 | 08:34 PM
occultworks's Avatar
I should hope 24 psi isn't maxing out the "green." I'm reading that this thing just flows a lot of air.
Old May 31, 2007 | 09:43 PM
RazorLab's Avatar
OEM mitsu 9
Old May 31, 2007 | 09:57 PM
kimletrim's Avatar
Registered User
Is this because the Denso 720s aren't that much different than the 660s?
Old Jun 1, 2007 | 12:41 AM
dsmfan95's Avatar
Isn't dadriva running Denso 720's?
Old Jun 1, 2007 | 12:49 AM
RazorLab's Avatar
Some more data:
From the dyno in 3rd gear,
22 psi - 7031 rpm - 86% IDC
11.2 afr
Another FP green on 100 octane (not my car, but same denso 720's):
3rd gear
23 psi - 7020 rpm - 84%
11.4 afr
Old Jun 1, 2007 | 06:01 AM
nothere's Avatar
is there some miscalculation when you run an injector at an injector scale that is not exactly the same as your injectors. iow there may be a little fudge factor in the reported duty
