Lower Degree Thermostat
Old Jun 2, 2007 | 04:02 PM
evo 9 guy's Avatar
Does anyone know if there is a company or anything that makes a lower degree thermostat for the evo 9's? any intel would be greatly appreciated.
Old Jun 2, 2007 | 04:07 PM
ak47po's Avatar
http://www.lancershop.com/customer/p...&cat=93&page=1
Out of stock though.
Old Jun 2, 2007 | 04:10 PM
evo 9 guy's Avatar
sweet thank you
Old Jun 2, 2007 | 09:06 PM
Whoop_ass's Avatar
do these actually work for anything, i have one just got to put it in
Old Jun 2, 2007 | 09:17 PM
EvoDan2004's Avatar
I'm wondering if I should get one. But I here there bad since the car needs to run at a serten temp. I here mix reviews about them. Anyone have any pro con info on them
Old Jun 4, 2007 | 12:41 PM
EvoDan2004's Avatar
bump
Old Jun 4, 2007 | 01:03 PM
Ted B's Avatar
unnecessary
Old Jun 5, 2007 | 12:51 AM
MACH3EVO's Avatar
ok thermo stats you want oil or water Billion (jap) make heaps of these OIl tomei,HKS
worth doing if you do track work
Old Jun 5, 2007 | 11:13 AM
dxbevo9's Avatar
i have the ralliart one and i really like it...it keeps the engine cool on the high way but in stop and go traffic the car will run at normal temp...
i have the 68F one!!
goodluck
Old Jun 5, 2007 | 01:09 PM
JKav's Avatar
Waste of money. Unless you like having poor fuel economy and washing down your cylinder bores with excess fuel.
Old Jun 5, 2007 | 02:52 PM
Erik@MIL.SPEC's Avatar
Hypothetically, if you have one, wouldn't the point you make be moot if you have a tune?
Old Jun 5, 2007 | 03:11 PM
Evo8yurAMG's Avatar
i dont see why its a waste of money, they are cheap and how does it hurt the motor the aftermarket thermostat just flushes the water out of the motor sooner. the water is still hot as hell. just doesnt let it get as hot as normal before flushing it out for the water in the radiator.
Old Jun 5, 2007 | 03:21 PM
Dave Mac's Avatar
The ONLY thing the thermostat does is activate the cooling fan. (A thermostat is a temperature activated electrical switch) The coolant is ALWAYS in constant circulation in your engine and through your radiator when your car is running. Just as the oil in your car is ALWAYS in constant circulation when the engine is running.
Old Jun 5, 2007 | 03:32 PM
I am pretty sure there is a SPRING in the Ralliart thermostat that opens more at a lower temperature than the stocker.
Besides, how does the thermostat turn on the fan? I am looking at a thermostat right now, and see no electrical connection whatsoever.
Old Jun 5, 2007 | 03:38 PM
sabastian458's Avatar
That isnt true. Have you seen a thermostat? There isnt an electrical connection on it to control the fans. The thermostat acts as a restriction in the coolant system to promote faster warm ups. It keeps the coolant return passage closed off until the specified temp (88 degree C) is reached, then it opens, allowing the coolant to flow through the radiator.
