Burshur DP Question
Old Jun 6, 2007 | 09:01 AM
Redline-Z's Avatar
Veteran: Air Force
Burshur DP Question
Ok I have done some searching and guess I don't know what to call it. I installed a MR Manifold/O2 Housing and Buschur TBE yesterday and my DP is tight against the front "cross-bar"
Is this supposed to happen? It doesn't make noise or rattle but I am concerned it will dent my DP, help me out please!
Old Jun 6, 2007 | 09:04 AM
TeStUdO's Avatar
Didnt your dp come with spacers? My Buschur did.
Old Jun 6, 2007 | 09:17 AM
Redline-Z's Avatar
Veteran: Air Force
I didn't get any spacers with my kit
Old Jun 6, 2007 | 09:19 AM
TeStUdO's Avatar
Call them and tell them. They will probably hook you
Old Jun 6, 2007 | 09:23 AM
Redline-Z's Avatar
Veteran: Air Force
Ok do the spacers go on the bolts that hold the crossbar, if this is the case I have hardware in the shop right here. Is this how you remedy this, will it affect anything?
Old Jun 6, 2007 | 09:26 AM
TeStUdO's Avatar
You can remedy it with longer bolts and spacers for the crossbar. You could definitely pick them up from Home Depot.
Old Jun 6, 2007 | 09:27 AM
Redline-Z's Avatar
Veteran: Air Force
Solved, Thanks!
Old Jun 6, 2007 | 12:46 PM
BURNALL_4's Avatar
They go between the cross bar and the orgional mounting surface of the bar. And you use the supplied longer bolts...
Old Jun 6, 2007 | 01:11 PM
Jrod@Buschur's Avatar
Your exhaust should have came with a hardware kit in the box. It has ALL of the hardware to install the exhaust along with the spacers. How did you install the rest of the exhaust? We pre package the hardware kits prior to shipping so we make sure everything is in them that is needed.
Its a good chance it was overlooked in the bottom of the box. Some times it gets mixed in with the shredded paper.
dkorr
May 14, 2014 08:33 PM
paintball272003
Jun 7, 2013 01:08 PM
coolguycooz
May 12, 2007 12:50 AM
Turbotoyzz
36
Feb 21, 2007 12:53 PM
ant_turbo
Jan 1, 2007 11:03 PM
