Wrong Tune!!
Old Jun 6, 2007 | 09:21 PM
4rcd6's Avatar
Im gonna use TTP once i get my cams in... plenty of good tunes from my buddies rides here in the Miltown area...
Old Jun 6, 2007 | 09:23 PM
evoracingstar's Avatar
i would bring it to a shop that are specialist in evo's make more power!
Old Jun 6, 2007 | 10:00 PM
Waz996's Avatar
4rcd6: 400 engine!! If it were wheel i wouldnt complain that much..
The curve is sooooooooo out of phase!
Thanks guys for replies.. I'll get in touch with TTP and follow the boost leak issue closer.. I'll let you guys know, at least i know now the tune is not OK!
Wael
Old Jun 6, 2007 | 10:39 PM
XK120's Avatar
Good luck Wael...your Evo is just waiting to be unleashed!!!
Old Jun 6, 2007 | 11:59 PM
erioshi's Avatar
Was that a pump gas tune? If so wouldn't a 50 trim respond better to more octane?
IIRC the larger turbo options don't respond well unless you can run better quality gas to allow the early timing & extra boost needed to wake up the bigger turbos. Adding water and/or methanol injection may also help to wake the car up.
Old Jun 7, 2007 | 12:40 AM
Waz996's Avatar
pump gas here is 93 i recogn.. it says 98 OCTANE in the pump stations
Old Jun 7, 2007 | 04:02 AM
dxbevo9's Avatar
guys...Wael got it a little confused here...this is a mustang dyna and he made 396WHEELhp...it is not engine horse power...
However,,i still think there is something majorly wrong the tune...the car is not making enough torque....maybe as most of you suggested it could be a boost leak but i doubt....i think its the tuner....i really didnt feel good driving Waels car yesterday...i immidiatly felt that my car was faster with the same mods but with stock turbo....
we will get him retuned and find out the issue...
however that is is whp/wtrq....and believe it or not this is my old VERY conservative tune....now i am making 397whp/376wtrq on the same dyno at 1.6 bar ~24.5psi
our pump gas here is 98oct europ spec which is equivilant to us 93oct..
later
Old Jun 7, 2007 | 07:07 AM
chase123's Avatar
Isn't the Hp/Tq curve suppose to cross at 5252 rpm not 4750
Old Jun 7, 2007 | 07:33 AM
juyanith's Avatar
Yes, but the torque and hp are not on the same scale. Look at the left and right axis labels.
Old Jun 7, 2007 | 07:37 AM
chase123's Avatar
I figured I was missing something.
Old Jun 7, 2007 | 07:54 AM
NoTec's Avatar
Without alky, race fuel, or aem ems, I don't think this guy stands a chance. The tune can probably be a bit better on pump but Wael will continue to loose. The IXs over here are seeing about 400-420 whp on an un-manipulated Dyno Dynamics dyno with those mods and alky. On pump gas the power falls of considerably. Gotta go alky, high octain, or ems in my unknowing and lowely opinion.
Old Jun 7, 2007 | 09:47 AM
Waz996's Avatar
AND he had the decency to LOCK my ECU!!!! HE locked it...
Thank Malibu (Aktivematrix..) I unlocked it!!
I strongly beleive this setup can make much more and i am working on getting it right.. I think i just have to work on it.. Help me out guys, pls no need for comments to put me down!!!
Wael
Old Jun 7, 2007 | 01:46 PM
TTP Engineering's Avatar
Let us know when you are ready Wael.
Old Jun 7, 2007 | 03:39 PM
gunzo's Avatar
later
That is a dynamic test systems Dyno .. It calculates ENGINE HP when you select TORQUE as display output by using some form of calculations when it does the drivetrain loss test at 2500rpms ..
When you select boost or AFR, then the output is WHEELS
Wael, you're running a bigger turbo with the similar boost to stock .. your higher rpms are better than stock .. but below that .. it's worse .. sounds normal ..
You have to run higher boost to shine .. and the torque curve looks normal for that type of dyno with your 50trim ..
golgo13
For Sale - Cars For Sale
41
Jan 27, 2016 11:50 AM
golgo13
37
Apr 4, 2014 04:32 PM
jonny2735
13
May 18, 2012 10:33 AM
1NastyMR
22
Mar 28, 2011 08:52 PM
Kakihara
Sep 30, 2008 05:25 AM
