Oil Light?
Old Jun 17, 2007 | 06:13 PM
lakeman's Avatar
Oil Light?
So I noticed a couple weeks ago my oil light was on and then went off. I checked my oil and I was a couple of quarts low at 2500miles. Anyways, I thought lets go ahead and get the oil changed.
Okay got the oil changed drove the car home. Haven't driven the car for a week.
Went to go get some gas and it came on again. Once I started driving it went off.
Any suggestions?
Thank you
Rob
Old Jun 17, 2007 | 06:21 PM
scottatyamaha's Avatar
What brand and weight oil are you running? Also being a couple of quarts low at 2500 miles is not a good thing, I know the evos burn some oil but only about half of quart per 3000 miles.
Old Jun 18, 2007 | 10:29 AM
lakeman's Avatar
Mobile 1 synthetic 5W-30. This is my second evo and I agree that it shouldn't be that low at 2500 miles.
Old Jun 18, 2007 | 11:51 AM
Kee1pride's Avatar
do an oil light search. same thing just began happening with my car about a week ago. there is a switch behind the block under the intake manifold that sensors the oil. it costs about 25 bucks to replace the part and about an hour worth of time to change. im lazy. my car is fine and i've ran the hell out of it with the oil light on. at first i was scared and turned the car off imediately. a friend came to look and told me the sensor isn't reading properly or what ever. however when driving if the light stays on then its a serious problem. if it goes away with any throttle, you're good. search "oil light" if you need more confirmation on that so you can rest better.
Old Jun 18, 2007 | 11:56 AM
Thegame's Avatar
Chances are you're not modded yet, so take it to the stealership and see what they can do for warranty work. I know, I know... It's easy to do though!
Old Jun 18, 2007 | 06:03 PM
lakeman's Avatar
Thank you for the help guys. Kee1Pride's description is exactly what's happening.
Again, thanks for everyone taking the time to post.
Rob
Old Jun 18, 2007 | 07:38 PM
J-ROC's Avatar
Rob
most likely its your oil pressure sensor...
Old Jun 18, 2007 | 08:42 PM
revvin9k's Avatar
Umm, he said he was a couple quarts low when he checked it. I don't know how much oil your Evo holds, but, if mine were a couple low, i'd be worried at 2500 miles.
