lifter tap and loss power!
Old Jun 19, 2007 | 08:37 AM
RedLanEVO's Avatar
does anyone think that the lifter tapping can cause our evo's to lose power? there's a few people in the forums that have experienced loss power after the tapping begun. made me think about when i installed my cams, @ 18 lbs of boost, i was passing my brother's STi like nothing. a couple days later, i hear ticking. i race my brother again, this time with 100 octane and 25psi, and i never pull away. my set of JAM lifters are coming in this week. i'll install them and see , but i really want to know if that tapping has anything to do with power loss because my car just runs ****ty right now even with my new 20ggreen
Old Jun 19, 2007 | 09:02 AM
hondafan's Avatar
i could see excessive lifter noise getting to the knock sensor, the ECU seeing it as knock, and thereby pulls timing and adds fuel to lose power. so yes, i think it would be possible. our knock sensors seem to be pretty sensitive.
Old Jun 19, 2007 | 08:48 PM
RedLanEVO's Avatar
hmmm ok. yeah, i recall someone saying they lost about 20whp when they began hearing the lifters tick. its weird but i guess i'll find out...although mine only ticks on warm-up, even in really hot weather..but only on warm-up.
Old Jun 19, 2007 | 09:18 PM
hondafan's Avatar
if they're not making excessive noise under wide open throttle, then i don't think that's the problem. if they were, it could cause phantom knock just like someone with a DP that taps the crossbars, and the ecu thinks it's knocking and starts interpolating the low octane map into the high to reduce timing and increase fuel for a margin of safety.
Old Jun 21, 2007 | 09:28 PM
RedLanEVO's Avatar
ok, so i installed the new lifters for JAM. foolowed their instructions and ticked on start up. after that, no ticking! test drove it and ...wow, what a difference! i can actually feel the 20g now..pulling all the way to redline. 2nd gear is fast! i am not exaggerating at all.
Old Jun 21, 2007 | 11:23 PM
Erik@MIL.SPEC's Avatar
JAM lifters FTW
Old Jun 22, 2007 | 05:25 AM
tehforbes's Avatar
it really made that big of a difference?! man my lifters tick like crazy after i put my 272's in.....probably cuz i didnt bleed them
Old Jul 31, 2007 | 09:56 PM
1.8tfanatic's Avatar
Ordered MIne
I just ordered my JAM Lifters today. Cant Wait !!!
Old Aug 1, 2007 | 06:35 AM
EVO8LTW's Avatar
Some people get tick with the JAM lifters too.
Old Aug 1, 2007 | 06:41 AM
Soon2BEVO's Avatar
I installed the JAM lifters and I still have tick, but its a different kind of lifter tick now... awesome. However, no power loss from it, just annoying at idle in hot weather.
Old Aug 6, 2007 | 06:15 PM
colonelfox's Avatar
I had a similar tick last summer that was worse in hot weather. It turned out to be a bad main bearing slowly wearing down. If swapping lifters didn't get rid of it, cut open a used oil filter and carefully check it for chunks of copper bearing material. In the beginning stages a spun bearing sounds a lot like a lifter at idle.
Old Aug 12, 2007 | 01:24 PM
Cirrusly Evolvd's Avatar
My ECU is pulling timing between 2-3K and I've developed a nice tick in the valvetrain so I'm going to swap out my lifters and see whats up.
Old Aug 12, 2007 | 02:08 PM
jrsimon27's Avatar
how can someone know the diff between a main bearing and a lifter?
Old Aug 12, 2007 | 05:03 PM
Smogrunner's Avatar
I've had a fairly loud valvetrain tapping sound for 15,000 miles. Much louder than the typical ticking folks get with the installation of cams, etc. If that was a bearing, my engine would have went BOOM a VERY long time ago.
Old Aug 12, 2007 | 07:42 PM
C6C6CH3vo's Avatar
Because a main (or rod or balanceshaft) bearing will cause lifter tick when when it first starts wearing. Once the bearings cause knock at the bottom you'll likely need a crank. Metalflake oil seems to cause oil pressure problems so lash adjusters don't work right. The oil can appear clean with rocker cover off, and even with a bunch of copper sludge on the bottom of your sump you may not see much flakes in the filter.
The only way to check is drop the oil pan - it's easier than cutting a filter (or your finger off)
