How to install ATP gt35r?
Old Jun 19, 2007 | 04:24 PM
blackonblackevo's Avatar
How to install ATP gt35r? I am in the process and having issues.
Old Jun 19, 2007 | 04:40 PM
scheides's Avatar
EvoM Moderator
remove old turbo
install new turbo
tune
drive
done!
Seriously though what are you getting hung up on?
Old Jun 19, 2007 | 04:47 PM
Boost Addiction's Avatar
Wow this guy can't decide what to do!
First he tries to sell the turbo kit and
nobody is interested,so then he now
wants to install it? Interesting stuff.
Later
Old Jun 19, 2007 | 05:13 PM
Well the thing is am I suppose to use the stock water lines and oil lines?
Old Jun 19, 2007 | 07:27 PM
I can only find one coolant line to connect to the gt35r that is next to the engine on the side, Is their some other coolant line I am not seeing or missed? I tried using the stock oil drain pipe from my evo 9 turbo but it does not fit on the gt35r. The kit came with one base plate like the one's ont the end of the stock oil drain pipe from the evo 9 turbo. I am thinking of splicing the stock evo9 turbo oil drain pipe and connecting it to a tube that connects to the turbo for the oil drain. Any body have any suggestions. Am I doing something wrong.
Old Jun 19, 2007 | 07:50 PM
hondafan's Avatar
so their kit doesn't have any install instructions/tips? that's great customer support!
Old Jun 19, 2007 | 08:10 PM
I did not see any instructions with their kit. I could not believe it. When I called for technical support the lady who picks up the phone told me to send a email to ATP. That really sucked. I was surprised.
Old Jun 19, 2007 | 09:09 PM
High_PSI's Avatar
I just bolts on to the OEM manifold, not that hard.
Old Jun 19, 2007 | 09:22 PM
I'm not talking about the manifold.
Old Jun 20, 2007 | 04:52 AM
deadbeatrec's Avatar
i had Pruven do mine. they used stock coolent lines along with what came with the kit.
Old Jun 20, 2007 | 08:01 AM
cssaddictm4's Avatar
Its ATP...I havent had much luck with customer service...
Side note, directly from ATP:
"100% bolt-on design. No welding, cutting, or fabrication"
You must not have found the other coolant line.
Old Jun 20, 2007 | 08:50 AM
I see the two coolant lines, One reaches to the turbo, the other seems short even when I use the stock coolant line to try and connect it. The stock drain pipe for oil does not fit to the turbo. What pieces or parts do I use to connect the turbo to the oil pan to let out the oil from the turbo.
Old Jun 20, 2007 | 12:04 PM
hondafan's Avatar
sounds like maybe the housings need clocked a little bit to move the center section to a different position. did you try that?
Old Jun 20, 2007 | 12:10 PM
mine had to be
Old Jun 20, 2007 | 03:26 PM
I had to my own oil drain line becuase the kit cam with only one flange. How would I install a forge mbc to work with the atp gt35r kit?
