View Poll Results: What Modification Sequence should i take?
SLAM DUNK all components
33.33%
Perform each mod individually
66.67%
Voters: 15. You may not vote on this poll
Modification Sequence help = Benefit EVOM Members
Old Jun 20, 2007 | 04:52 PM
Aby@MIL.SPEC's Avatar
FP-GRN, GSC S1 Mod. Sequence help = Benefit EVOM Members
So i will be receiving my gsc s1 cams ~ 1 week prior to receiving my 20g-LT/FP-GRN turbo.
On top of this, i have a sheetmetal intake sitting in my garage waiting to be installed as well......yeah, i am a power junky, point me to WHP Anonymous!
Anyway, here is my delimma...
If I decide to install all these components @ once, Then i may as well yank the head too, throw in some +1mm larger valves, port the head & sort out my combustion chamber, since the only thing keeping me from doing this are 10 head studs/nuts!
or
being he purist i am, install each of these components seperatly to note the power gains of the gsc cams against my previous hks set-ups, the merit of the new turbo to over the tme i currently have (which will be for sale soon w/custom licp), then perform a intake manifold dyno compare for everyone to see while being run on california's finest 91 octane & just wait to port the head later
I would take any & all paypal donations (~$5-) to help subsidize the cost of 3 separate dyno compares!
aby.smfr@gmail.com
if you make a dyno time donation, please make it public
If the individual dyno's dont happen, I will refund all donations via paypal & you loose nothing
GSC S1 cams vs. previous HKS 272i/264e @ -3/0 & HKS 280's @ -3/-1
TME vs FP-GRN with gsc s1 cams
OEM Intake vs. Modified Weapon-R with FP-GRN & GSC S1 cams
Old Jun 20, 2007 | 04:53 PM
EvoBig16G's Avatar
yes please do the the second method. I have HKS cams with TME turbo and would like to see what kind of gains you get.
Old Jun 20, 2007 | 04:55 PM
cangriracing's Avatar
ive read this forum for a while i didnt know people ported the heads for this car. How much whp does that get
Old Jun 21, 2007 | 05:50 PM
no other input?
i figured i would hear a lot on this extremely opinionated forum?!!!!!
Old Jun 21, 2007 | 06:16 PM
superflyevo's Avatar
do it all at once you will like it way more
Old Jul 3, 2007 | 04:04 PM
my fp-grn just arrived.....2 day's earlier than the expected date from ups!
still waiting fort he gsc s1 cams => tracking # claims to arrive on the 5th.....
Old Jul 3, 2007 | 05:01 PM
mudduck's Avatar
Ideally, you should add one by one with dyno-tunes after each step, or else you'll end up with no idea which mod actually made power... (this is assuming that you could gather enough EvoM donations... - hey we better not see you sporting a brand new Full-Race 42r setup next week either )
My last upgrade consisted of ported/coated exhaust manifold, LICP, and GSC S1 cams, and 750cc injectors - followed by custom tune. To this day, I regret not knowing if the first two of those mods did anything whatsoever.
So far, you've really taken the time to build a nice pump gas/street set-up using the right combo of parts. So what happens when you install the cams, intake mani, and FP green and only make 25-30whp? Then you'll be running around with a sub-optimal setup without knowing which part of the three wasn't the best of its kind.
Aby@MIL.SPEC
Aug 6, 2016 10:23 AM
Aby@MIL.SPEC
Oct 15, 2014 01:00 PM
Aby@MIL.SPEC
15
Mar 20, 2009 12:08 AM
Aby@MIL.SPEC
26
May 29, 2008 09:34 PM
Aby@MIL.SPEC
37
Mar 11, 2008 11:18 AM
