how can I know if it is the clutch or the synchro?
Old Sep 29, 2007 | 02:41 PM
  #31
dodgecoltracer's Avatar
+1, also have this problem. Its my DD, so am I going to have to leave it with them or can they do this in a day?
Old Sep 30, 2007 | 06:54 AM
  #32
FastAzzEvo's Avatar
my fifth gear is sucky too. However, I have an act clutch so I doubt mitsu will fix it under warranty. I just have to let the rpms fall some before engaging into 5th. That seems to work, or slowly put it in gear.. can't quick shift or it will grind.
Old Sep 30, 2007 | 07:47 AM
  #33
If I'm stock, you think mitsu will waranty my sycros?
Old Oct 1, 2007 | 09:31 PM
  #34
evovin's Avatar
5th gear started to grind 2 days ago now every time i shift to 5th gear it feels that i get hurt too
so will mitsu warranty this even i have a rebuilt motor? im still on stock clutch.
If not how much will it cost me to rebuit?
is there any cheaper way to fix my 5th gear grindng than this>>>https://secure.buschurracing.com/cat...7b90ed5397df87
Old Oct 2, 2007 | 08:18 PM
  #35
evovin's Avatar
i just installed my zaklee shifter bushings....hope it will help.
Old Oct 2, 2007 | 09:52 PM
  #36
MSFIT's Avatar
i was getting pretty bad 5th gear grind, after shifter bushings it went away.
now its coming back and 4th is worse than 5th now.
to add to it my clutch is going.
