mivec head evo8cams hmm
Old Jul 1, 2007 | 10:30 AM
kaonashi's Avatar
Ok guys this is my problem, i have a good evo9 block, no ecu wiring harness, can i stick my evo8 cams in the head and run it off the evo8 ecu or would this probably be stupid for me even thinking about it.
Old Jul 1, 2007 | 10:46 AM
Ph3n1x's Avatar
no
Old Jul 1, 2007 | 11:23 AM
CBRD's Avatar
are u asking if you can put an evo 8 head with cams on a ix block?
or use a ix head with 8 cams?
cb
Old Jul 1, 2007 | 11:44 AM
slicedbreadno2's Avatar
I think he means the head since he is referring to mivec head. Anyways you will need the Evo IX wiring harness and ecu. The VIII cams I am sure that they won't go with with the IX head. If you can get the Evo IX ecu and wiring harness you'll be good to go. You'll just need to sell the VIII cams and get IX cams. Good luck
Old Jul 1, 2007 | 11:55 AM
scottatyamaha's Avatar
Well he also has no wiring harness for the mivec, that is why he wanted to put the 8 cams in the 9 head so he can use his 8 wiring harness.
Old Jul 1, 2007 | 01:57 PM
kaonashi's Avatar
I figured it wouldnt work and for the record, you cannot use a evo8 head on a evo9 block i found that out the hard way, so i might end up trying to locate a evo9 ecu and wiring harness.
Old Jul 1, 2007 | 03:09 PM
Evo 9 ecu's shouldn't be too hard to locate, but the wiring harness will require a bit more effort.
Ksay3
Dec 9, 2015 03:26 PM
ptm5070
Jun 1, 2015 07:36 AM
TurboTravis
Dec 8, 2012 11:35 AM
sba
Oct 23, 2010 11:24 PM
Evo8Emperor
22
Dec 9, 2007 04:51 PM
