HKS Blowoff Valve
Old Jun 26, 2003 | 07:30 AM
midwestmonster's Avatar
HKS Blowoff Valve
Anyone have this installed and noticed once in a while in stop and go type traffic, your rpms dip alittle and come back up? Mine just started doing this. Anyone know what this could be caused from? It doesn't do all the time, just sometimes. I got the blowoff valve recirculating, so I heard this shouldn't happen. Please help!!
Old Jun 26, 2003 | 08:52 AM
SikWitIt's Avatar
I have a Open Atmosphere BOV and mine does it every now and then. But if yours is recirculating than I don't think you should have a problem. Make sure the fittings are as tight as you can get them.
Old Jan 17, 2004 | 10:43 PM
evo7788usa's Avatar
the blowoff valve
hey I got the same question like u got!!
it feels like leaking the air but dont know where!!
and my friend told me that you need a safc to fix it ...
so .....
if u want to . u could just leave me the messege or something and we can talk about this together!!!
Old Feb 25, 2004 | 08:42 PM
girlxevo's Avatar
rpm dropping is not normal for hks. try adjusting the screw tighter
Old Feb 25, 2004 | 09:12 PM
JaReDbOy's Avatar
its perfectly normal.
i have the HKS SSBOV.. recirc'd, and mine does that all the time. it will even occasionally stall.. but its not that bad.
i believe doing the grounding kit or the SAFC will fix that. i think the MAF gets screwed up from the different air flow setup.
Old Feb 25, 2004 | 09:35 PM
dirty_barry's Avatar
It could very well be the MAF and the ECU getting readings they aren't used to with the new blow off valve. Check how tight the screw is and see if it is possibly opening up early or sticking.
-Brady
Old Feb 25, 2004 | 09:53 PM
xkpbreaker's Avatar
VTA bov's will cause accidents be VERY careful..... for example.... while ur making a nice high speed turn and u let off the throttle and the rpm dips and ur car stalls out... before u can even notice it u'll be in deep trouble...
Old Feb 26, 2004 | 05:30 PM
SilverCOEvo's Avatar
Slighly off topic, but I noticed a similar thing in stop and go (totally stock Evo, hence the slightly off topic). I figured out quickly that I have to have the clutch ALL the way to the floor or my RPMs will drop to about 400 when I come to a stop with the clutch in and the car in 1st gear. It almost feels like I just have to apply a bit more pressure, no noticable clutch movement. I'm going to look into a slight clutch adjustment to remedy this...probably not your issue, but I figured I'd chime in since I was seeing similar behavior.
Old Feb 26, 2004 | 05:35 PM
masterevo's Avatar
Off topic again, but not by much. Does anybody in here run the greddy type s VTA? I'm going to try to see how bad the idling/stalling problem will be. As for Recir, it's perfect; works like stock. All you have to do is remove the inner spring and you're set to go. Peace..
Old Feb 26, 2004 | 05:39 PM
EvoJimbo's Avatar
Let me enlighten you guys. Have you notice that air gets sucked in through the adjster screw? Take it off and try it! You can actually feel the sucking if you put your fingers there. So better make sure the screw is not on the loosest setting.
wallace989
20
Sep 27, 2011 01:53 PM
urnamehere
Oct 13, 2010 12:01 PM
EVOgirlIX_MR
Feb 22, 2009 01:41 AM
locox
Oct 5, 2008 05:46 PM
IgotaWhiteOne
Jan 23, 2004 10:37 AM
