My turbo died..need help
Old Jul 10, 2007 | 09:43 AM
  #31
TeStUdO's Avatar
Originally Posted by V8eatr
The shop did a compression test and leak down test.
Did you look at the compressor blades yet?
  #32
bluebyu36's Avatar
did you call them back and tell them what happened??
  #33
V8eatr's Avatar
Originally Posted by laxhero2
You should have just taken it back to the shop although, they probably denied anything that might have went wrong with the car. But i would complain to them because they were the last to drive it but let us known what happens.
Im getting it towed today so im going to talk to them about everything...ill definitly keep you guys updated...if its the turbo im planning on getting the evo 9 20G turbo 10.5 with the evo 9 turbo install to evo 8 kit.
Old Jul 10, 2007 | 09:47 AM
  #34
V8eatr's Avatar
Ive been at work all day but last night i checked out the compressor blade and i couldnt get the best angle but it didnt look to be damaged although the shaft play it had felt a little much.
Old Jul 10, 2007 | 09:50 AM
  #35
V8eatr's Avatar
Well ive been going to this shop for 5 years so they are my good friends now and ive talked to them about 5 times since last night and they are saying from all the description and sounds that its my turbo. Within the past 2 months its been kind of funny...like it just didnt feel like it was pulling as hard as it should. I really didnt think anything of it but now its all coming together. I know its either a boost leak or my turbo.
Old Jul 10, 2007 | 10:28 AM
  #36
bluebyu36's Avatar
good luck
Old Jul 10, 2007 | 11:40 AM
  #37
sonicnofadz's Avatar
If the turbo did not have excessive shaft play, the vanes were not damaged, and spun freely, the turbo is fine. Do a compression check and a boost leak test. You may have skipped some teeth on your timing belt, who knows.
Old Jul 10, 2007 | 09:40 PM
  #38
evo150's Avatar
my bet is you have a leak at the gasket between the turbo outlet pipe and licp.
Old Jul 10, 2007 | 10:34 PM
  #39
DynoFlash's Avatar
By the shop do you mean THE SHOP in Norwalk, CT - if so bring the car back we will look it over and diagnose it for free
Otherwise go back to your shop and have them look it over
AL
Old Jul 11, 2007 | 03:45 AM
  #40
Freddy302's Avatar
Not sure..but if you BOV got stuck open, your car would have a really hard time making boost. From what I read it sounds like the turbo is ok..
Old Jul 11, 2007 | 03:52 AM
  #41
krazy srt4's Avatar
sounds like the death whine to me!!!...if ur gonna upgrade i would go bigger atleast like a gt30 or 35r
Old Jul 11, 2007 | 04:53 AM
  #42
V8eatr's Avatar
It was the death whine...i put it back together in my garage yesterday and drove it to the shop really slowly. The whine sounded like a siren from a firetruck and then i would hear the turbo start to spool and seconds later you could hear the compressor blade just clinking and it would stop. Its like a 99.9% sure its my turbo...the death whine is giving it away. Im going with the FP Evo Green Turbo and then having ams re-tune it for me cause they arent to far from my house.
Old Jul 11, 2007 | 04:55 AM
  #43
V8eatr's Avatar
AL
No i go to CarV2 in Wilmington, Delaware. Ive been going there for 5 years. Sorry for the confusion.
Old Jul 12, 2007 | 12:05 PM
  #44
V8eatr's Avatar
Well we took out the turbo and turns out it was my turbo that died and not a boost leak or anything else. Have a FP Green (ported and coated) on the way with a Walbro 255 fuel pump, 780cc injectors, TurboXS front mount followed by an AMS tune.
Old Jul 12, 2007 | 04:33 PM
  #45
EV0lved's Avatar
Originally Posted by 4G63-KID
if you have a friend with a evo, try his turbo on your car. see if it helps
you are a moron
Icegod87
Oct 21, 2014 11:15 PM
hatakashi
Oct 8, 2013 01:22 PM
alex the great
Mar 23, 2013 09:48 PM
yahu
48
Apr 13, 2010 07:09 PM
evo3barboost
Sep 14, 2006 11:28 PM
