fuel psi
Old Jul 11, 2007 | 02:34 PM
haloevolution45's Avatar
Question fuel psi
Was woundering if anyone knew what psi to set your presseure regulater too with 780cc injectors?(ams pressure regulater with gauge not the stock one by the way) i have it set at 42psi cause thats what the manuel said but i dono if thats just for the stock injectors. one more thing, this is gonna sound stupid but the car at high rpms and boost like around 4 half 5 grand starts to feel like its not getting enough fuel or prob too much. (looses some power) thats prob because im not tunned yet for these injectors im guessing?
Old Jul 11, 2007 | 02:44 PM
alpha's Avatar
42lbs is fine. Stock turbo? What fuel pump? Wideband O2 in the car?
Old Jul 11, 2007 | 02:47 PM
cssaddictm4's Avatar
Originally Posted by haloevolution45
Alpha posted faster than I could, lol. +1
A. Idle PSI is about 42psi with vacuum pinched. about 60-70psi under full boost (30psi boost for me)
B. Could be getting too much or too little fuel under boost. Do you have a wideband? Stock ECU could be pulling timing if it is seeing knock.
Old Jul 11, 2007 | 02:51 PM
i never pincehd any vacuum lines though. am i suppose to keep the one from the intake manifold pinched? it reads 42 without it pinched. im still waiting for my fp green to get here and i have walbro 255 fuel pump and ams fuel rail. thanks,
Old Jul 11, 2007 | 02:52 PM
o and i dont have a wide band :/ i was told to not get one cause they dont last long. only use them when tunning.
Old Jul 11, 2007 | 02:58 PM
You are misinformed my friend. If you are refering to not lasting long with C16, then thats a different story because not many O2 sensors last when using leaded gas. Having a wideband O2 is almost imperative when driving a modified turbo car, if not just a safety precaution.
Old Jul 11, 2007 | 03:02 PM
looks like ill get me one then ha ha o ya and after the car sits for a bit the psi drops to 0 its suppose to right? sorry dono much about the fuel pressure. but i thought it was suppose to stay with a lil bit of presseure.
Old Jul 11, 2007 | 03:04 PM
I believe it all depends on the gauge type. My Autometer electric gauge sometimes reads at 20psi or sometimes 0 when the ignition is off. If the ignition is in the on position then it jumps to 20-40psi. I don't know what my new AEM one will be like.
Old Jul 12, 2007 | 05:11 AM
okay thanks for the info
Old Jul 12, 2007 | 06:47 AM
KevinD's Avatar
after a while the fuel pressure will drop to 0, that is normal. it will flow back through the pump, also out the regulator, and sometimes out the injectors very slowly.
Old Jul 12, 2007 | 06:50 AM
subrwho's Avatar
Shaun, I told you that you were wrong about widebands not lasting long!
Old Jul 12, 2007 | 08:36 AM
CO_VR4's Avatar
Your ECU assumes that you're using stock injectors and stock fuel pressure. Your fuel pressure should be set at stock initially, and your ECU should be flashed or a standalone mapped to compensate for the increase in fuel caused by the difference between the fuel injected by a signal to your stock injectors and the amount of fuel for the same signal sent to the 780s that you've installed.
Old Jul 12, 2007 | 08:39 AM
alpha's Avatar
I have had widebands last a year to two years with little to no leaded gas
Old Jul 12, 2007 | 09:24 AM
SuPeRNeT's Avatar
Mines lasted 2 years and still is fine
