Injector question!!
Old Jul 13, 2007 | 02:18 PM
MREvolution06's Avatar
Injector question!!
I'm getting ready to install a FP Green turbo and was wondering what size injectors would be good to run with this?
Old Jul 13, 2007 | 02:28 PM
sabastian458's Avatar
I had the same question. I was told that my 780's were large enough.
Old Jul 13, 2007 | 02:48 PM
Joshs EVO's Avatar
I just got a 20g and I have the 780's
Old Jul 13, 2007 | 02:52 PM
Sweet thanks fellas.
Old Jul 13, 2007 | 09:32 PM
sparky's Avatar
You may wanna checkout Fuel Injector Clinic´s special offer on injectors. They are selling 750´s for $269/set, and 880´s $280/set. The price includes o-rings.
Old Jul 13, 2007 | 09:40 PM
EB05EVOVIII's Avatar
might as well get 880s if you havent bought them already that gives you enough room to grow as they say. if your plannin on running meth then the 780s should be fine.
Old Jul 13, 2007 | 09:45 PM
34Turbo's Avatar
If you'll be tuning with the stock ecu, I wouldn't recomment going over 780cc's. 880's would be pushing it but you should be fine. Also, are you going to be running alky? If so, then 780's should be more than enough...
Old Jul 14, 2007 | 11:31 AM
sparky's Avatar
Yeah, I have the Denso 720´s which I´d bought a long time ago, so I just slapped those in. But, they are barely adequate for the Green and some peeps have seen 95% DC(i.e., "WOT") with the 720´s at 24+ PSI on this turbo.
So, if I had it to do over again I´d just go with the 880 cc nozzles. The 750-780´s might not be up to the job at 30 PSI on race gas w/o Alky. Why take the risk of running static at higher boost levels.
Old Jul 14, 2007 | 05:43 PM
Mellon Racing's Avatar
I'm going to run 680's on mine since I'm regulating it to pump gas boost levels.
Old Jul 15, 2007 | 02:15 PM
Oracle1's Avatar
750 on oem ecu OK for 30 psi, only 85%.
shomesomesho
Dec 10, 2016 09:22 AM
talonkev
Oct 18, 2013 05:12 PM
xRoguex
12
Jun 18, 2013 04:32 PM
LakerRaider
Jun 24, 2010 10:28 AM
Billy@EnglishRacing
Northwest Region
11
Jun 17, 2008 10:02 AM
