P0403 Exhaust Gas Recirculation Circuit Malfunction
Old Jul 13, 2007 | 02:27 PM
VT Mitsu's Avatar
Anyone have any experience with this one?
Basic mods w/ mech fix for res. test pipe.
Just got back from dealer who replaced my exhaust mani. Long story. Just trying to figure out what I can maybe check before my appt. on Tues.
Thanks in advance for any help rendered
Tom
Old Jul 13, 2007 | 02:54 PM
sonicnofadz's Avatar
Make sure the vacuum hose is still connected to the EGR valve (they tend to pop off under high boost). Try applying a 12 volt signal to the EGR valve and listen to see if you hear the valve solenoid "click". If theres no click, its dead. As a last resort, remove the EGR valve, and inspect it for cracks, they have been known to crack and leak on even very new Evo's (06). Good luck!
Old Jul 13, 2007 | 02:57 PM
SiCKlEyWiKeD's Avatar
EGR vavle. Check the hoses
Old Jul 13, 2007 | 02:59 PM
Also, type p403 in a search. I guarantee a lot of threads will pop up
Old Jul 14, 2007 | 01:13 PM
VT Mitsu's Avatar
The following errors occurred with your search:
Sorry - no matches. Please try some different terms.
Tried PO403,po403, po 403, etc....first About all I do on here is search. Joined a year ago and have only piped up 70 times or so No worries. I'll check the EGR valve (as soon as I find where it is in my Mitsu CD Service manual
Thanks for the recommendations, gentlemen.
Sonicnofadz, any further suggestions as far as maybe resistance/voltages measured for the Valve? or is it just click or no click for working/not working?
Tom
Old Feb 20, 2008 | 12:21 AM
ajstefanacci's Avatar
where are the hoses and were is the valve. i have the p0403 light on. on my throttle body theres 2 hoses on the top that go to a block thats broken. is that the valve?
Old Feb 20, 2008 | 12:22 AM
Wicked E's Avatar
The EGR valve is below the TB. A gold metal disc like thing...
Old Feb 20, 2008 | 06:09 AM
C6C6CH3vo's Avatar
Describe the block. Both lines go to the egr solenoid mounted lower aft of engine (can barely reach it from above engine). One of the lines is tee'd directly to egr valve underneath TB, the other reaches the egr valve from the solenoid.
It is a PIA replacing the solenoid.
Old Jul 30, 2011 | 01:47 PM
GUnited's Avatar
uhhh bump from the dead. I have the same problem... p0403 ugh. any updates? was it the egr valve?
ccr100s
Mar 4, 2015 11:06 AM
4g63mr808
Aug 17, 2010 05:45 AM
november
Sep 20, 2009 07:59 AM
Malik_EvoIX
18
Jan 7, 2008 09:17 AM
DickMorgan
May 26, 2007 08:08 PM
