GT35R over GT37R
Old Jul 14, 2007 | 03:40 AM
Ev0cRaZy's Avatar
dont have a scanner here...
Old Jul 14, 2007 | 07:53 AM
crcain's Avatar
Originally Posted by Ev0cRaZy
I drive a stock block, 272HKS cams Evo8 everyday with a GT37r turbo on a blowthrough setup. No problems whatsoever, I hit full boost @ 4500-5k.
I want to say that Dave Buschur said that he saw full boost (~36 psi or so?) at well past 5k on a 35R.
So explain to all of us on this board how you managed to spool a 37R sooner than that!
Old Jul 14, 2007 | 08:29 AM
High_PSI's Avatar
I BELIEVE AMS has quoted 300 RPMS slower.
Old Jul 15, 2007 | 05:18 PM
Migsubishi's Avatar
True but not everyone can super tune like AMS, nor does everyone have the capabilities of having AMS tune there car! The average good tuner is still seeing 600-1000rpm laggier.
Old Jul 15, 2007 | 05:28 PM
4cefed's Avatar
i can have evocrazy's back here i have pretty much the same setup and power and I hit full boost at the same time.
buy the 37 and never look back
Old Jul 15, 2007 | 05:29 PM
CBRD's Avatar
do what we do...
try the 35R, if its not enough, put another compressor wheel on it
wink wink
cb
Old Jul 15, 2007 | 05:33 PM
High_PSI's Avatar
[QUOTE=Migsubishi;4541951]True but not everyone can super tune like AMS, nor does everyone have the capabilities of having AMS tune there car! The average good tuner is still seeing 600-1000rpm laggier.[/QUOTE]
Wow!!!!!! That is bad!
Old Jul 15, 2007 | 05:34 PM
diablo2184's Avatar
well if you're gonna use nitrous then just go with the 37R
Old Jul 15, 2007 | 05:58 PM
Migsubishi's Avatar
Do you have a dyno graph, My butt dyno told me I had full boost at 3800rpm on high compression 2.4l with the PT 67mm and .68a/r T4 housing. The aem log said it was at 5100, some people get confused with quick spool andfull boost. It will yank real hard before it gets to full boost,and for this reason and this reason only do I ask for proof.
Old Jul 15, 2007 | 11:00 PM
diambo4life's Avatar
Yeah...all that is bull****. Not spooling a 37R by 4,500rpm. Show a datalog or dyno chart with logged boost and RPM. By "full boost" we are not talking about 10psi either.
Old Jul 15, 2007 | 11:03 PM
34Turbo's Avatar
It all depends on the 35r and 37r you are comparing, manifold design, cams, and tuning... My boys 37r (Buschur everything) actually spools up only a couple of hundred rpms after my 35r.
Old Jul 15, 2007 | 11:54 PM
chuntington101's Avatar
35rs have worked great on loads of 600+BHP track cars over here. great spool and no lag at all.
i have heard good things about the 37 but i would probably go for the 35 first and see what you think. if you want more power then you can upgrade.
by the way, has anyone fitted a 40R cold side the the 35R hotside????
thanks CHris.
Old Jul 16, 2007 | 02:37 AM
WongFu's Avatar
Well i have a Shearer gt35r and ive heard nothing but great things about them. Hell BR also uses his manifolds so it should be alright. I just dont want to buy another turbo unless its worth the money.
Old Jul 16, 2007 | 03:19 AM
Ev0cRaZy's Avatar
I really dont care what some of you think, I was trying to be helpful and some of you just wanna be asses. Yes I DO hit full boost at 4500-4700rpms, I do run a Blowthrough setup which made a 300-500rpm faster spool when I installed it.
Old Jul 16, 2007 | 03:32 AM
Spaceball 1's Avatar
no one will believe you since you post no dyno sheet and all of the big shops quote about a 5K spool on the 35r and about 500rpm higher for the 37r, plus you quote 509whp which is completly easy with a 35r
Now for my input i just bought a 35r kit cause i will never push the limits of the 35r at 600whp, 500 to 550whp on a dynapac will make me happy. The 37r is old technology wheels mated to the new design bb center, which is the reason for the slower spool, and way less power before complete spool say at 4K rpms. yes the 37r will beat it out on the top end by roughly 50whp. Also most people that are going 37r are going with a 2.0 or 2.1 build becuase in the quarter they are running out of revs in fourth gear. Dan B is a great example if you about his car.
