Buschur exhaust probs
Washing my car the other day I noticed that the muffler pipe was off center. I looked under to car and sure enough the metal hanger that is welded into the exhaust broke off. No biggy I though, just get it welded again, and I also notice that it didn't just come unwelded, the damn thing broke a square peice of the exhaust and now it's leaking and making that odd sound an exhaust does when it's holed. Oh well. It never fails.
So now I got a coat hanger holder the damn thing up until I have enough time to fix it. You think Buschur will fix it for free?
my friend has their full exaust on his evo
his 1/4 time were always at least .5 sec worse then mine.
we ran at the same time
we have same mods,except he has the full 3"exhaust.
How do you explain that?
Also, the 3" turbo back system from Buschur is a 3" mandrel bent stanless steele pipe. All manucaturers use the same damn thing, some even restrict it more with resonators. This is straight throughw/ testpipe, so it is evident that it is much better than the stock exhaust.
Try calling Buschur Racing and calling. As for them knowing about the forum...did you not notice their banner ad?
David Buschur is a registered member of the forums and has posted around a few times.
No, it is a very good idea. There are mixed feelings about using a 3" downpipe VS a 2.5 into a 3" downpipe. Some DP's start out 2.5 and open to 3"... just making a generalized statement.
Ah, gotcha.
It looks like in order to reduce weight they used thin pipe, could be the contributing factor for the hanger breaking off so easily. Thin walls.
Originally posted by stvbreal
You mean to tell me that upgrading to a 3" turboback isn't such a good idea?
He launches just like me at 5-6 rpm, he car has less miles then me. Always looses.....
2.5" vs 3" downpipe
No gains? Where did you hear this from?
So Buschur 3" turboback, air filter and testpipe don't amount to any gains? How about with a boost controller and S-AFC? I'll gaurantee ya some gains there.
954DRGSR, trade cars with him and see what happens. Also, not every car will run the same, some are just naturally stronger from the factory. You can't compare two different cars with similiar setups, it just don't work. Have him dyno before and after the exhaust swap, under similiar air temps/conditions, thats the only way you can judge improvement.
I know my exhaust increased off the line wheel spin capability, and it sure sounds a hell of a lot better.
stvbreal, call Buschur, likely they will make good on the exhaust, as it sounds like a freak flaw.
Originally posted by 2Cool
954DRGSR,
954DRGSR,
