The Turbo Landscape in Detail
Bump for more info on my last two questions
Garrett does not produce twin-scroll GT35R but Turbonetics does... does that mean Turbonetics casts a special turbine housing on their own?
Another question... why have I never heard of an Evo running a Turbonetics turbo?
And can someone explain to me.. the GT37R or I think what is called T67 P-Trim...
I believe this is a turbo from a company called Precision Turbo?
How specifically is this turbo developed? What is it derived from?
precision makes a turbo called the PT6776 P trim. It was used and tested by AMS and they worked out a deal to coin the name GT37R. There is no actual GT37R, but this PT67 that everyone calls a 37R. Its just a combination that precision put together and happens to work very very well
Hi Steve thanks for the info.
Is the PT67 a Garrett unit to start? What Garret parts do they start with. What is modified?
A brief look at Precision's website did not help me much. They seem to have a dozen model numbers "6776".
A PT67R is a T4 turbo. It has a 76 trim T4 turbine and a T04S compressor wheel with a 67mm inlet diameter. It uses a variety of compressor and turbine housings.
Breaking down the model name...
"PT" = Precision Turbo
"67" = 67mm inducer
"R" = ball bearing
I assume a PT67 (without the "R") is the same thing only using a non-ball bearing center section.
Today the only TRUE Garrett GT37R turbos are in their Cummins and Duramax diesel upgrade kits.
"67" = 67mm inducer
"R" = ball bearing
this is our variation on the same turbo. It uses a p trim turbine wheel (76 trim 11 blades) and a 66.7mm 63 trim compressor wheel (84mm exducer, 6/12 blades)
generally, it is believed that the 10 bladed GT turbine wheels are more efficient, and the GT compressors (52-56 trim) are more efficient than the 63 trim compressor used here. GT turbos can be found at www.turbobygarrett.com
edit: i forgot to mention that the GT37R is almost the same turbo as the HKS T04Z, which is very popular in japan. i dont know why but the japanese prefer the HKS stuff to garrett GT turbos
Ok if we compared the PT67 to let's say the Garrett GT3582R.
The GT3582R is:
Turbine: T3 84 Trim with A/R choices (.63, .82, 1.06)
Compressor: 56 Trim with 61mm Inducer and 82mm Exducer with AR .70
Garrett says the "Whl Dia" of the turbine side is 68mm. I'm not sure if that means the inducer or exducer.
So now comparing this to the PT67...
The GT35R has a larger trim on the turbine side, but then a smaller housing T3 versus T4. I can't compare the size of the turbine wheels themselves as I'm unsure how to read this from the Garrett catalog.
The compressor of the GT35 is a 61mm inducer 56 trim. The PT67 is a 67mm inducer and I don't know its trim.
Anyway just speaking out loud here trying to make sense of how you understand the physical dimensions of these turbos. Maybe we can talk about compressor maps once I get a handle on this stuff?
The GT3582R is:
"67" = 67mm inducer
"R" = ball bearing
"67" = 67mm inducer
"R" = ball bearing
The PT67R uses a T4 turbine wheel (which is a 74.2 mm wheel; or larger than a T3). This comes in a variety of T4 housings, and apparently T3 housings are available too. You'll have to call Precision for the details.
Its compressor wheel is an 84mm 63 trim T04S, same as the one Geoff is using above.
Again the PT67R (aka "GT37R", which completely misleading) is nothing more than a plain ol' T4. Not saying it's bad, just saying what it is. The BB aspect is nice.
While the GT3582R uses an 82mm 56 trim compressor wheel, it is not apples to apples based on dimensions. You have to consider the wheel aero itself, plus the effect of the housing. I wouldn't be surprised if the GT35R's flow potential was similar despite its smaller dimensions.
And then there is efficiency to consider....
Edit: I remembered that a T4 wheel is 74.2mm major diameter
This is what I've gleaned so far after doing a bit of math which I think is correct?
Code:
GT3582R PT6776R
Turbine Housing T3 T4
Turbine Inducer 68mm 74.2mm
Turbine Trim 84 ???
Turbine Exducer 40.8mm ???
A/R 3 options ???
Compressor Exducer 81.5mm 84mm
Compressor Trim 56 63
Compressor Inducer 61mm 66.6mm
Ball Bearing yes yes
What does the term T3/T4 mean? Does it mean you are mating a larger compressor side with a relatively smaller T3 turbine housing?
What does the acronym "H.O." mean?
What does the part number "TO4R" refer to? What about "TO4S"? Are these Garrett par numbers for compressors?
What about "p-trim"? What does that mean?
What is wrong with my maths here?
From this URL:
http://www.turbobygarrett.com/turbob...o_tech102.html
I get the formula for exducer calculation to be:
Exducer = Inducer / squareroot(Trim / 100)
Is that correct? I can't believe how bad my algebra has gotten over the years!
From this URL:
Update
Code:
Garrett Precision Full-Race Garrett
GT3582R PT6776R FR T3/T67 GT3076R
Turbine Housing T3 T4 T3 T3
Turbine Inducer 68mm 74.2mm 67mm 60mm
Turbine Trim 84 ??? 76 84
Turbine Exducer ??? ??? ???
Turbine A/R 3 options ??? 2 options 3 options
Compressor Exducer 81.5mm 84mm 84mm 76.2mm
Compressor Trim 56 63 63 56
Compressor Inducer 61mm 66.6mm 66.7mm 57mm
Compressor A/R .70 ??? .70 .60
Ball Bearing yes yes yes yes
