Pls help, car wont start after cleaning fuel filter.
Old Jul 17, 2007 | 05:59 PM
x7eVoLuTiOn7x's Avatar
I have a EVO 7. Had the injectors cleaned. Also had the tank fuel filter cleaned, drained the fuel tank. Now the car wont start. We checked the injectors, all working. We also disconnected the battery to reset. Still the same problem. What seems to be the problem? btw, also checked the sparkplugs...all are working fine, giving out sparks...all are dry. Pls help guys!!!!!! thanks.
Old Jul 17, 2007 | 06:07 PM
evoracingstar's Avatar
sounds to me that the battery hit the hey (died) for good. that happen to me after a while wen i had my small battery!
Old Jul 17, 2007 | 06:10 PM
sharkm87's Avatar
does it try to crank?
Old Jul 17, 2007 | 06:16 PM
Nad1370's Avatar
air lock in the fuel lines...
Crack open the fuel rail and start cranking till fuel purges out.
If no fuel comes out...then your fuel pump is not turning on.
Let me no Pre'
Old Jul 17, 2007 | 06:21 PM
AlwaysinBoost's Avatar
when you put the key on the "ON" position, do you see the "Check Engine Light"?
Old Jul 17, 2007 | 08:45 PM
thanks for the reply guys. Already solved the problem. We opened up the fuel pump again & rechecked the connections. The culprit was an oring that was not put back properly. The car now freakin is way faster than before!!!!
EvoIXMR671
Mar 17, 2017 07:15 AM
AutoEuphoria
Apr 23, 2016 08:11 PM
iggypooper
Aug 2, 2012 10:31 AM
tonylocc
26
Mar 24, 2010 04:09 PM
ctdragon
10
Mar 6, 2005 06:19 PM
