Hope for 91 Octane guys
Old Dec 18, 2004 | 12:47 AM
mrbkkt1's Avatar
tried using toluene mixture today. i figure a 15-1 ratio w/ 92 octane & toluene is o.k. makes a difference. when using 100 octane mix and 92, the car runs on a different "map". i ran a tank of 92 again, and the map changed again. today using the toluene mix, the car switched back to the more agressive map. the car hits boost a lot smoother w/ more than 92 octane.
Old Dec 18, 2004 | 12:06 PM
Jon H's Avatar
http://www.clayeye.com/fuelcomputer.xls
Old Dec 19, 2004 | 12:16 AM
David Buschur's Avatar
Guys, you should really check out the alcohol injection kits we have instock now. The kit uses the factory intercooler sprayer bottle as the resevoir, it holds about 1.5 gallons so it lasts a long time. The alcohol can be bought at any Home Depot or hardware store. Nice thing is you aren't burning it up while you are just driving it around. The system uses a progressive controller, so you can set at what boost levels it starts to come on and when it maxes the spray out.
We are getting buy with 25 psi of boost on 93/94 octane with ease.
The problem with the boosters, as I see it anyway, is you add them and then drive around and burn them up even when not in boost. You have to make sure you have either booster or alcohol but with the alcohol you have 1.5 gallons that only gets sprayed when you are in boost (I usually set them up to not come on before 14 psi). This can make a 1.5 gallon tank last a very very long time. The controller also has a low level light on it so you know when you should add more. Controller is about the size of a pack of cigerettes.
Just another option. I have been impressed by the kits and what it will allow you to do.
David Buschur
www.buschurracing.com
Old Dec 19, 2004 | 01:08 AM
mrbkkt1's Avatar
no intercooler spray on my evo(05) , will be considering other options though.
Old Dec 19, 2004 | 01:11 AM
mrbkkt1's Avatar
Originally Posted by Jon H
Thanks, that was very very helpful. never thought of using excel. much easier than using calculator.
Old Dec 19, 2004 | 02:15 AM
Jon H's Avatar
David Buschur
David,
Would you happen to have a picture of the controller?
Old Dec 21, 2004 | 03:00 PM
Pictures of the kit are on our website.
The '05 can still use the alcohol injection, we have a "generic" bottle for general applications too, much smaller, same price.
DAvid
Mauricio Evo IV
Feb 2, 2017 01:50 PM
monsta
Jun 23, 2016 01:11 PM
Dem_z
Lancer Aftermarket Forced Induction Tech
26
Jan 17, 2007 02:01 PM
Evo442
Oct 2, 2006 05:01 PM
Evo442
Feb 25, 2004 01:25 PM
