Egr?
Old Jun 28, 2003 | 02:00 PM
Sickdriver's Avatar
Egr?
Does the evo 8 has an EGR?*
If so where is it, and has anyone tried to remove/block it?
Could something like this work?
http://www.myzero.com/engine/egr.html
*The EGR (exhaust gas recirculation) is a walve that recirculates burned gasses back into the engine to limit pollution. Bottom line it hurts performance.
Old Jun 28, 2003 | 03:25 PM
BadBoyBeltran's Avatar
I think so since the ECU has an EGR pin. Will blocking it off turn you CEL on? If it is, do you know any other way to block it so it wont turn it on?
Old Jun 30, 2003 | 04:47 AM
mayhem's Avatar
different application but the same thought discipline. Only read the first few paragraphs that give explanation.
http://www.ttzd.com/tech/egrtech.html
Old Jun 30, 2003 | 07:56 AM
bryans2k's Avatar
It will throw a CEL after a while with it disconnected. I tried... I think the reasoning was that the evo has a pressure sensor in the manifold which is new to the model? It is suppose to be able to sense the pressure difference when the egr was suppose to be activated?
Bryan
fostytou
359
Oct 23, 2025 09:54 AM
JohnBradley
Sep 29, 2015 11:17 PM
Beluga
Lancer Engine Tech
Nov 1, 2012 08:06 AM
bbyevo8u
May 14, 2010 03:01 AM
phabaznbro
Apr 18, 2008 07:44 PM
