Wastegate?
Old Jul 24, 2007 | 03:42 PM
gbmoto313's Avatar
Wastegate?
Where exactly is the wastegate located on our cars does anyone have a diagram?
Old Jul 24, 2007 | 03:48 PM
Luis@TTP's Avatar
it bolts on the turbo housing between the radiator and the turbo stock color is gold.
Old Jul 24, 2007 | 04:11 PM
SiCKlEyWiKeD's Avatar
oh wow. Maybe you shouldn't own a turbo car lol
Old Jul 24, 2007 | 04:15 PM
Kdash106's Avatar
find the turbo, u shall find the wastegate.
Old Jul 24, 2007 | 06:39 PM
KenMasters's Avatar
Don't listen to any of them.
The wastegate on an evo is internal. It is a flap that opens inside the turbine housing. Hence the o2 housing not being a piece of pipe. That little gold can on the outside of the turbo is the actuator. A spring loaded diaphragm that opens a butterfly valve that lets the excess gasses go.
Does this help????????
Old Jul 24, 2007 | 06:48 PM
the chosen one's Avatar
do you actually want a diagram?
Old Jul 24, 2007 | 06:50 PM
Mivecless's Avatar
Everyone needs a chance to get aquainted with their car.
Old Jul 25, 2007 | 12:29 AM
sparky's Avatar
Originally Posted by KenMasters
The wastegate on an evo is internal....It is a flap that opens inside the turbine housing..... A spring loaded diaphragm that opens a butterfly valve that lets the excess gasses go.
The word, "internal", is a misnomer. A more accurate word would be "integral" as it applies to the 16G's WG. The WG is not a flap inside the turbine housing either. The WG actuator does not open a butterfly valve. The WGA keeps the WG puck, aka flapper valve, shut.
Old Jul 25, 2007 | 06:05 AM
Luis@TTP's Avatar
after you find the acctuator if you cant tell that evo turbos are internal wastegates there might be something worng. so if someone discribes the actuator as a wastegate they are discribing part of the system.
Old Jul 25, 2007 | 05:13 PM
KenMasters's Avatar
Your talking apples and oranges Sparky.
Explain to me what you think the diference between a "butterfly" and a "flapper" valve is.
I have never heard the term "flapper" to describe a valve.
I install valves for a living.
Old Jul 25, 2007 | 05:23 PM
bandilero's Avatar
some people need a little help..... just help the guy out or say u dont know.
all i can really say is the the gold part u see is the actuator. without a diagram i couldnt tell u exaclty where to go but i do agree that, u find the turbo u will find the wastegate
