MBC problem, not a leak, but sucks just as much
Old Aug 3, 2007 | 09:43 AM
VtexGt3's Avatar
Okay, so i changed out all the hoses, and the fitting for the IC pipe and made sure there were no leaks. However, i still hear what sounds like the wastegate opening and dumping at and apporaching 13psi. The car will pretty much hit a wall at 13psi, and not boost any higher, the sound stays the same level and such. I have a Hallman boos tcontroller hooked up properly, use from a member, its hooked up to the BOV and intake mani line infront of the T off where my boost guage is hooked up to. Not sure what the problem is.
Could it be that hte MBC isn't work? so its reverting to wastegate pressure and dumping from there. At 3 turns i get 13 psi and lots of noise. at 0 turns i get somewhere in the 5 psi area.
Should i hook it up to the turbo housing nipple instead of hte bov,intake line?
not really sure what else it could be.
Old Aug 3, 2007 | 10:18 AM
sharkm87's Avatar
i have that same setup and works great...you sure the bov is holding boost?
Old Aug 3, 2007 | 12:49 PM
dan628's Avatar
You should always use the turbo nipple as the source, I don't know why so many people insist on use the BOV to intake line. Try that.
VtexGt3's Avatar
yea, i'm gonna go and check all the clamps again, and see if i can hunt down where the noise is ocming from...
Old Aug 3, 2007 | 12:57 PM
LoRo's Avatar
Turbo Nipple > MBC < WasteGate
I think that should fix your issue.
Old Aug 3, 2007 | 01:32 PM
Luis@TTP's Avatar
what he said^
Old Aug 3, 2007 | 02:38 PM
VtexGt3's Avatar
going to try that right now, TTP! with this leak i can't even see how great the tune i just got from you guys is going to be!
Old Aug 3, 2007 | 02:40 PM
Luis@TTP's Avatar
ok keep me posted
Old Aug 3, 2007 | 02:48 PM
SiCKlEyWiKeD's Avatar
Turbo nipple and WG set-up= Boost will not spike as much but is known to taper more and spool will be a little slower
Intake line and WG set-up= Faster spool but will spike more because of it, also will hold boost better.
That's why most people go with the intake line way.
Old Aug 3, 2007 | 03:10 PM
VtexGt3's Avatar
does the turbo nipple make a difference in terms of this little dilenma of mine? if all else fails i can always drink my problems away!
Old Aug 3, 2007 | 03:13 PM
did you swap springs before you installed it?
Old Aug 3, 2007 | 03:24 PM
Luis@TTP's Avatar
you can pick up positive boost from there and the wastgate vacum line should be connected. or you can pick up positive boost from the intake like has been said befor.
Old Aug 3, 2007 | 03:30 PM
VtexGt3's Avatar
well it was a used mbc from a member, so i don't knwo which sping is in there... and he didn't give me the other one..
Old Aug 3, 2007 | 03:33 PM
might wanna check that, if the light spring is in there then 13psi sounds about right.
Old Aug 3, 2007 | 04:35 PM
VtexGt3's Avatar
interesting will do riight now haha
