Cosworth 272 Cam Idle Rise and Fall
I have the same problem on my VIII with 272 cams. I had my ecu flashed after the install so i thought that would take care of it but i was wrong. Still can't figure it out has any one found a way to fix this yet?
gonna bring this one back from the dead in case anyone has found a fix yet. Same problem...idle stumbles down to around 500 or so and goes way lean then catches it self and goes back up.
fixes?
fixes?
i've been tuned and raised the idle to 1k rpm and it still dips - gonna have Sean look at it this week and I'll post up results, just do a friendly bump on Friday if I've forgotten so I can remember to discuss results. . .I'm on GSC S1's. . .
i am curious to see how many people DONT HAVE this problem...
i have even left my car on idle for several minutes and the only rpm change i change is a slight movement when the fan goes on... as soon as it stops the idle falls to normal rpm and its almost rock steady...
went to Sean Ivey today to get retuned with the exhaust and have the idle issue taken care of - he managed to eliminate most of it, ECU is still relearning, but he raised the idler on the TB and did "something" in the flash. . .it should hold, feels amazing:
Just something I noticed last night and to add to discussion.
I normally run 93 octane from Shell but last night I filled up with unleaded 100 octane and although the car's idle still behaved the same, the AFRs never rose above 16.1 which is odd because it used to stumble into full lean "- - -" at idle.
The wierd part is that it still behaved the same, would stumble then after a few seconds surge slightly but this time the AFRs were almost "acceptable" Anyone else experience the same thing or have access to a higher octane fuel to see if this can be replicated?
Anyone smarter than me want to take a stab at whats wrong with the cosi cams, or my setup?
P.S. At cruise and WOT my AFRs are in check.
Maybe he can chime in here...
If anyone wants me to help them out. Take a log at idle and send me your map/xml def./log for your car and I can do the same thing I did for him to test and see if it helps....
~Zach
