Cosworth 272 Cam Idle Rise and Fall
Old Aug 11, 2007 | 04:17 PM
msukach's Avatar
I've had these cams in for about 3 weeks...great mod/power--I'm running 350 whp. However, I've been searching EVOM for solutions to an idle "problem." My idle has that familiar low tumble (loopy) when it's hoovering at about 950...that's fine but the idle continues to rise to about 1100+ and fall to 700-650 (almost feels like it could stall) intermittently if I'm just sitting.
I'm come across some threads on the topic of cams/idle but not something which addresses this rise/fall situation. I'm not an expert w/ECUflash, but if someone can suggest an adjustment that might help prevent the rise/fall of my idle, I'd appreciate it.
You'll see from the snapshot that the RPM neutral and drive parameters have been adjusted quite significantly from stock but no adustments to the desired ISCV initial step position settings. I have changed the value of the RPM neutral and drive parameters from 1039 to lower increments down to 1000--that does effect the rise and fall by increasing the interval between when it happens...there only seems to be a slight reduction in the rise/fall thing itself.
Attachment 110087
Old Aug 24, 2007 | 05:58 AM
joel(PA)'s Avatar
im having this same issue. tried to tune it out a little but to no avail, will fall from idle at about 900 rpm down to 500 where the car feels like its going to die.
I thought somehow i might be a tooth off on my cam gear but now that i see someone else is having the same issue i am doubting that.
Old Aug 24, 2007 | 06:25 AM
phenem's Avatar
If someone wouldn't have turned the cams when we had the tensioner tool in there and skipped a tooth!! Just leave it alone it sounds cool!!!
J/K, we will figure it out, IF YOU CAME TO THE DYNO DAY TOMORROW WE COULD FIX IT!!!
I will ask my buddy there to see what he does for Cosi's and their infamous idling issues. If anyone would know he would.....or at least have an idea on how to fix it.
~Zach
Old Aug 24, 2007 | 08:46 AM
joel(PA)'s Avatar
~Zach
i cant go to the dyno day, i have a wedding i have to go to. this is the only post i have seen with idling issues with the cams
Old Aug 24, 2007 | 08:49 AM
phillytec's Avatar
Smile
Mine do it too( but not all the time). Try raising your idle on you throttle body.
Old Aug 24, 2007 | 09:47 AM
liquidh's Avatar
I am exp the same thing with my 272's on my IX
Old Aug 24, 2007 | 10:49 AM
kouzman's Avatar
i also have the mivec cossie cams...
i have to say that my idle is almost like stock when the car is in normal operating temprature.
some people dont even believe that i have cams!!!
Old Aug 24, 2007 | 11:07 AM
StreetThisEvo's Avatar
Mine idle just as you describe. I'd like to find a fix.
Old Aug 24, 2007 | 11:14 AM
boostless's Avatar
MAF sensor? Just a common guess from when I had a honda.
Old Aug 24, 2007 | 03:40 PM
joel(PA)'s Avatar
I don't think all of us are having MAF problems after just installing the cams...
my idle falls to about 600 rpms and leans way out 17:1+, then picks back up to about 13:1 at around 1000rpm and will sit there for a minute, then drop back to 600rpms again about to die and shaking the car. sucks pretty bad.
Old Aug 26, 2007 | 08:18 AM
phillytec's Avatar
Question
does any one know if hks cams 272 on the 9 do this?
Old Aug 26, 2007 | 09:40 AM
Jewish Santa's Avatar
Is this "problem" only for the IX or is this an issue on the VIII too?
Old Aug 27, 2007 | 03:30 PM
joel(PA)'s Avatar
bump for information: anyone get their idle figured out with the cossies?
Old Aug 27, 2007 | 04:45 PM
rsalicrup's Avatar
I would try that. 350z have the same problems when we install cams. We fix it by raising the idle speed.
Old Aug 27, 2007 | 05:26 PM
filter's Avatar
mine does the same thing (even through 2 diff tuners) i just assumed it was part of having cams. so i never payed attetniton to it till i seen this thread.
