Cosworth 272 Cam Idle Rise and Fall
Old Oct 6, 2007 | 05:32 PM
  #31
1QYK9's Avatar
I don't have an answer for you as to the idle problems as I don't have these cams right now, but am looking to get them. I am curious to know why your Evo isn't making more power given your mods. What psi are you running? My wife's Evo has a Nisei IC and piping and Hallman MBC and at 22psi the car is making 337awhp with 91 octane.
Old Oct 6, 2007 | 05:39 PM
  #32
wizzo 8's Avatar
Mine does the opposite. Somethimes it will go to 1500 at idle and then eventually go to the set 1000. This happens more when its cold. I have HKS 272s. If I lower the rpm to 900 with it become lumpier?
Old Oct 7, 2007 | 10:27 PM
  #33
msukach's Avatar
Just a note to add from my original post but I've noticed after a few hours of hard driving--running 100% meth--, the interval between the rise and fall of the idle is longer. In other words, it occurs less often...but this is only a passing observation. The fact that I've added meth may/may not have anything to do w/this problem.
Trouble shooting so far has involved raising/lowering the idle in ECUflash and changing out my walbro fuel pump--on the chance it might have been faulty and not maintaining pressure. I may next attempt new injectors...I'm running a stock turbo so I'm thinking the same size or slightly larger.
Feedback welcome...particularly anyone who has tackled and solved this problem.
Old Oct 7, 2007 | 10:56 PM
  #34
raiceboi697's Avatar
my problem went away once i raised my idol up on both the cold start map and the warmed up map....mine starts just like stock now, just sounds meaner....
Old Oct 9, 2007 | 03:01 AM
  #35
msukach's Avatar
What are your new idle settings?
To:
Old Jul 27, 2008 | 09:58 PM
  #36
brianevo9's Avatar
i have this problem with the idle as well, i wonder if its the timing>>
Old Jul 27, 2008 | 10:51 PM
  #37
SRT-TO-EVO's Avatar
I have this problem as well, but I'm on stock cams. I noticed it DID happen once I installed my ETS intake.
Old Jul 27, 2008 | 10:55 PM
  #38
red evo8's Avatar
increase the island of 4 in the timing map top left corner to 7 fixed it for me.
as stated in this thread
https://www.evolutionm.net/forums/sh...d.php?t=302895.
Old Jul 28, 2008 | 06:32 AM
  #39
brianevo9's Avatar
my timing is on the money with the 272 cams, the problem must be with something else
Old Jul 28, 2008 | 07:45 PM
  #40
red evo8's Avatar
boost leak would be the next thing that i would look at.
