Clevite part # for main & thrust bearing?
Old Aug 11, 2007 | 05:32 PM
TheLab's Avatar
anyone have a Clevite part # for Evo8 main & thrust bearings? Before I disassembled my engine I was informed by some older posts on these forums and others that 7 bolt 2G bearings applied, now that the engine is apart and I have 2G bearings I find this is definitely not the case lol. The interesting thing is in my Clevite book I list a part # for "Lancer 92+" but ironically enough it is the same part # as the 2G 7 bolt part # so needless to say Im not ordering those.
I know AMS and some other places sell Clevite bearings for the Evo 4G63, so what gives. What application are you all using when looking these things up? I guess my Clevite book is outdated or something.
btw, I need STD mains. Thanks guys/gals!
-bill
Old Aug 11, 2007 | 07:56 PM
GTREVO's Avatar
It is the same as a 2G motor, but when you buy the Clevites for a 2G you don't get the thrust bearing on the Evo with the 2G set. MOst end up getting the thrust bearing seperately from Mitsu. Its a seperate bearing.
ACL makes it for the evo. Try it, its just as good. They have the race series too.
Old Aug 12, 2007 | 06:08 AM
TheLab's Avatar
OK thank you for the info. My question is, if I use the 2G bearings then what do you do for the #3 journal? The 2G bearings on #3 have the upper AND lower thrust built into the main bearing. Obviously you only use thrust on the upper in the Evo. So if youre suppose to buy thrust washers from somewhere else I am also going to need a main bearing for #3 that doesnt have thrust washers built into them. The 2G mains with the thrust built in is way to wide to seat into the main cap/girdle assy.
obri'sevo
For Sale - Cars For Sale
May 1, 2014 04:11 PM
SmurfZilla
42
Jul 22, 2012 09:53 AM
quiquepr69
Jan 16, 2012 07:55 AM
SmurfZilla
Nov 15, 2011 08:16 AM
Evo3573
50
Sep 17, 2011 05:15 AM
