Does your BOV hold Boost?? What are you using?
Old Aug 14, 2007 | 06:48 PM
  #31
JMB8606's Avatar
I have a Baileys Motorsport DV/ Held 25psi during several boost leak tests. I havent tested it much higher than that.
BTW I have a almost brand new WORKS DV. I have never used it or tested it.
Old Aug 14, 2007 | 08:10 PM
  #32
rickandnobles's Avatar
Forge RS
Old Aug 14, 2007 | 08:54 PM
  #33
Erik@MIL.SPEC's Avatar
SO if your Forge RS is fluttering @ part throttle, do you need to tighten it or loosen it?
Old Aug 14, 2007 | 08:55 PM
  #34
4WS Tuning's Avatar
tighten
Old Aug 14, 2007 | 08:57 PM
  #35
MIVEC8's Avatar
WORKS DV is a rebranded JDM MR BOV right?
Old Aug 14, 2007 | 10:09 PM
  #36
JMB8606's Avatar
on there webside they designed it to hold more boost.
Old Aug 15, 2007 | 01:48 PM
  #37
Someone here tested the Works and Tomei.
In their testing the Tomei leaked @26psi and the Works leaked @ 27psi.
Old Aug 15, 2007 | 02:46 PM
  #38
SickSilverNLow's Avatar
Tial FTW......
Old Aug 15, 2007 | 03:01 PM
  #39
4ringturncoat's Avatar
I used a Greddy type s, I didnet check for leaks but I can tell you my stock 1g valve went 12.20's and drove great, my crushed 1g went 12.00's and drove not so great, and my Greddy S went low 11.90's and drove pretty good. The Type s had the small spring in it and the screw turned in about 6 turns.
Old Aug 15, 2007 | 03:06 PM
  #40
ExViTermini's Avatar
Originally Posted by SickSilverNLow
Tial FTW......
Old Aug 15, 2007 | 08:09 PM
  #41
joel(PA)'s Avatar
what about hks ssqv with the re-route kit? anyone have luck with this?
Old Aug 15, 2007 | 08:15 PM
  #42
akunochi's Avatar
Tial on AEM
Old Aug 15, 2007 | 08:54 PM
  #43
Luis@TTP's Avatar
Originally Posted by mikesevo8
Almost every BOV with an adjusment screw leaks there. That's what they make teflon tape for...
After having half a dozen BOVs tat leaked and had issues, I fashioned a tester out of HW store parts.
Attach the compressor and crank up the pressure...
Pic with Greddy RS unit
My MR valve leaked at 19psi. Crushed it held to 21psi.
I bought the APS dual vent. First test, and yes, it hissed at the screw. A little teflon tape and retest.
It held 40psi with no loss for over 5 mins. No complaints here with the APS unit
how do you regulate how mutch pressure it gets into this setup and where is the gauge saying it holds 40 psi im not doubting you just curious
Old Aug 15, 2007 | 09:04 PM
  #44
4doorbullit's Avatar
Originally Posted by ASE_Tech@TTP
greddy type s yes install alot of forge evo15 vales they work well also sisters to the forge rs and arent on back order like them.
I have forge evo 15 bov that I bought from ttp and I have ran 28 psi of boost with no leaks and no surging.
Old Aug 23, 2007 | 09:17 PM
  #45
Whoop_ass's Avatar
What spring have you got in your unit!!
i just installed mine and ...... well the partial throttle
is terrible, bucks and dives to the point were it is almost like massive surge!
i am gonna try different spring if that don't work!
I am gonna burn it and dance around it.
